Author Topic: th350 turbo speedo leaking  (Read 2941 times)
Offline impco lpg
« on: January 04, 2016, 03:30:16 pm »
my th350 trans speedo cable is leaking. i have replaced the seals for new ones, the outer seal o ring has worked but is still leaking from the inner seal. this is a common problem. has any one got a fix for this. ?
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
Re: th350 turbo speedo leaking
« Reply #1 on: January 04, 2016, 04:18:39 pm »
Remove the speedo driven gear and its support bushing (sleeve) from the transmission.  Slip the gear out of the bushing and inspect the shaft of the plastic gear for concentric scoring and a groove worn into the shaft near the cable end.  If the gear is grooved from seal wear, the gear will need to be replaced.  Now, slip the gear back into the support bushing and wiggle the gear from side-to-side.  If there is more than ~0.005" of side play in the gear shaft, replace the support bushing, as well.
Offline impco lpg
« Reply #2 on: January 05, 2016, 03:07:31 am »
thanks for your help i will try that when it stops raining :(
i should have replaced it all i think.
cheers neil
