Author Topic: 1979 Guage cluster swap into 1984  (Read 6317 times)
Offline onekarnut
« on: January 10, 2016, 09:01:27 pm »
Want to install tach dash from 79 Blazer into 84 Silverado with non tach dash. The difference in the two dashes is the tach dash moves the gas guage to lower left corner. Do I have to move any pins on the connector going into the panel and if so which pin is moved to what location on the connecter. Also what color wires are the connectors?
Thanks in advance.
Jim M
Re: 1979 Guage cluster swap into 1984
« Reply #1 on: January 10, 2016, 09:56:54 pm »
we have a whole technical section with wire diagrams and what not
http://forum.73-87chevytrucks.com/smforum/index.php?board=5.0
even the pin layout
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31456.0
this should answer your question
Offline Rattler12
  • Old Geezer
« Reply #2 on: January 14, 2016, 10:41:24 am »
Hey Irish......I was looking at your wiring links and got a question for folks. Those links show that an 83 NG cluster tied into the oil sender through a dark blue wire from  pin 3 and the gas sending unit with a tan wire from pin 18. My 83 C-10 non gauge cluster runs the tan wire to the oil sender from pin 3 and a pink wire to the fuel sending unit from pin 18. I traced the wires back through the printed circuit and tan goes to the oil idiot light and pink to the gas gauge. Did Chevy use 2 different methods?  Is my particular truck wired wrong from the factory or are the charts wrong?    Every other pin and corresponding wire color is the same with the exception of the seat belt reminder......in mine its black/wht stripe.  ?????????
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #3 on: January 14, 2016, 11:47:58 am »
idk for sure but i know on my 84 and 91 they match up
