Author Topic: Trans mount  (Read 4453 times)
Offline bcstingray
Trans mount
« on: January 17, 2016, 08:09:00 pm »
I'm looking for some info on a trans mount to replace the stock trans mount in my 73. It now has a manual 3spd trans and will be swapping in a turbo 350. I want to run dual exhaust and the stock mount has only one hump on the drivers side for the exhaust.
I will be running headman headers and 2 1/2" inside diameter exhaust.
Re: Trans mount
« Reply #1 on: January 18, 2016, 08:17:39 am »
There is a 4 speed cross member that will do what you want.  Usually dual exhaust can be routed to make it work but the right side is under the cross member.
http://store.73-87chevytrucks.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=7&Product_Code=SCRP7387&Category_Code=73-87UHood
Offline bcstingray
Re: Trans mount
« Reply #2 on: January 27, 2016, 07:09:47 pm »
I checked on that mount, but I don't want to drill any holes. Looking for a bolt up cross member.
Re: Trans mount
« Reply #3 on: January 29, 2016, 07:50:01 am »
dont remember the length of the trans sm465 vs th350 but i want to say the th350 is longer. so you will have to drill new bolt holes anyway
Re: Trans mount
« Reply #4 on: January 29, 2016, 07:27:00 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32506.msg275248#msg275248
just made this up today the sm465 is about 24" the TH350 is 27.68", 30.68" or 33.84"
Offline bcstingray
Re: Trans mount
« Reply #5 on: February 13, 2016, 11:40:16 am »
I finally crawled under the truck and found that the trans mount had been changed before. It has the humps on both sides for dual exhaust. I'll take some pics when it warms back up.
