Author Topic: alarm instal flash output question  (Read 5494 times)
Offline dsgb610
« on: January 23, 2016, 09:07:58 am »
Hello guys..
Installing an alarm on my truck, its a viper and the flash output wire is positive. It makes the parking lights flash when the alarm is armed/disarmed and when it is set off. In my truck i know  the parking light positive is brown.
Do i connect this directly to the brown wire or do I need a relay?
+flash output from alarm 86
+parking light wire on vehicle 87
ground to 85
+12V to 84
??? any help would be greatly appreciated.. Thank you
Offline LTZ C20
Re: alarm instal flash output question
« Reply #1 on: January 23, 2016, 02:27:58 pm »
I wish I could help here, I have a viper alarm also but my lights aren't hooked up to it. My old alarm before the viper was hooked up to lights and I didn't use a relay, I think it was hooked up just the way you said. I never had any problems. Maybe I should hook up my lights.
LTZ Cheyenne C20
Offline dsgb610
« Reply #2 on: January 23, 2016, 05:14:48 pm »
I went straight to the brown wire also, works good so far.
« Last Edit: January 24, 2016, 06:20:06 pm by dsgb610 »
Offline Chisholmcody
« Reply #3 on: February 11, 2016, 01:39:12 am »
Newer viper alarms have relays built into the brain for everything except the starter kill.
Offline dsgb610
« Reply #4 on: February 16, 2016, 06:38:53 pm »
Hey i got the alarm finished. Only relay I used was for the dome light not sure if that was even necessary but its working fine with it. added auto door locks in the process.
Offline LTZ C20
« Reply #5 on: February 16, 2016, 11:58:16 pm »
That's good. I need to hook up the wire for the light flash function on mine. Haven't done it. I didn't bother with the light flash function but who knows I might, the old alarm before the viper had it.
LTZ Cheyenne C20
