Author Topic: Short bed on a Crew Cab??  (Read 5886 times)
Offline Ziptar
« on: June 06, 2005, 01:04:00 pm »
What would it take to put a short bed on a 4X4 Crew cab??
Will a regular cab long bed frame do the job?? or would the crew cab frame need to be cut and shortend after the cab??
Offline roundedline
Re: Short bed on a Crew Cab??
« Reply #1 on: June 13, 2005, 04:25:00 pm »
The CrewCab frame needs to be cut after the cab and after the bed.  If you can mount the bed to the frame you can see where it should be cut.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
