Author Topic: Quadrajet jet/metering rod combos:  (Read 6146 times)
Offline Stewart G Griffin
« on: January 24, 2016, 07:45:48 am »
So, i'm (somewhat reluctantly) shopping for a "new" quadrajet. Why would some come with smaller jets and thinner rods, while some come with larger jets, but fatter rods? So, in other words, it seems the highway cruise fuel delivery settings are going to be similar.
This is just going to be for transportation and to get the thing running. i don't care about performance right now.
Re: Quadrajet jet/metering rod combos:
« Reply #1 on: January 24, 2016, 10:08:36 am »
My thoughts are what is the correct CFM needs for your displacement.  I am assuming it is for your 4.3L??  In the early 80's I really played around with 2 barrel on a 350 engine.  I changed the jets till I got the plugs looking/burning right and the tail pipe not black.  It took me several tries but I was getting 15 mpg in a 72 Chevy C10 and it had excellent driving manners and 3 mpg improvement over when I started.  This was probably a 65/35 split of in town/highway driving
Offline blazer74
« Reply #2 on: January 24, 2016, 11:30:23 pm »
Jet/rod combo's depend on several factors but what your asking is large jets and rods for large main air bleed and single main air bleed carbs,  smaller jets and rods for small main air bleed carbs.
« Reply #3 on: January 25, 2016, 07:41:00 am »
Yes, it is for the 4.3.  i can't get either of my quads or the 2g to run really good.  All 3 probably need to be rebuilt and i'm just really busy.
So...........larger air bleeds for larger engines,  smaller bleeds for smaller engines?
Offline blazer74
« Reply #4 on: January 25, 2016, 09:03:12 am »
No,  more air requires more fuel . Large are bleeds require more fuel ( larger jet) for correct fuel ratios. Therefore for requiring a larger rod for correct cruise fuel ratios.
The 4.3 you have came with a Quadrajet?  They were used with them or I should say v6's
Idle tubes, idle channels and jet/ rod combos were tuned for them along with limiting the secondary flap opening for the smaller engines.
« Last Edit: January 25, 2016, 10:05:49 am by blazer74 »
« Reply #5 on: January 26, 2016, 06:42:49 am »
Yes, the quad came on the first two years of the 4.3, for 85 and 86 on trucks.   i don't think the buick v-6 got it, instead they used 2g's or dualjets and i think the smallest 6 to get one was the pontiac straight 6 which was 230 inches!
Offline blazer74
« Reply #6 on: January 26, 2016, 07:22:58 am »
The Buick Grand National and v6 turbos had quads under the turbocharger except for the first year which was a 2g
Do you have the original quad off your v6 ?
« Last Edit: January 26, 2016, 08:56:26 am by blazer74 »
« Reply #7 on: January 26, 2016, 08:42:56 pm »
oh yeah--forgot about the grand national.   So, in that case the monte carlo turbo probably also had it?
i do not have the original carb from the 4.3
