Author Topic: Need help with speedo gear in 208 transfercase....  (Read 6828 times)
Offline K5blaze454
  • 4x4 performance
« on: January 25, 2016, 06:08:33 pm »
I have a k5 blazer with 350/700r4/208 with gm14 bolt  rear and gm10 bolt 4.11 gears sitting on 36s. as of right now i have 15 tooth output shaft gear and 35 tooth drive gear. all of the calculations i have done, thats what it calls for... >:( >:( i cant seemed to figure it out, can you guys help me? its doing 70 mph at 55 mph on my gps. Thanks in advance!! :D
« Last Edit: January 26, 2016, 12:35:32 pm by K5blaze454 »
Offline frotosride
    • WFO CONCEPTS
Re: Need help with speedo gear in 208 transfercase....
« Reply #1 on: January 25, 2016, 06:42:22 pm »
I have yet to replace my speedo gears and I have the exact same set up and close to the same speed at 55 mph. If you sent an email to TCI like the did they will tell you what gear you need to get it on track. If I find the email I will upload it.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #2 on: January 25, 2016, 06:55:59 pm »
What rpms are you spinning? And gps speed is 55, the speedo is fast at 70 correct?
 1986 Chevy K30(under repair)
Offline Captain Swampy
  • Wisconsin
« Reply #3 on: January 25, 2016, 09:41:26 pm »
Did you actually measure your tires height? Measure from the ground to the center of the axle and multiply by 2. It will probably only be 32-33 inches tall.  You have the gray 15 tooth gear and the orange 35 tooth gear? Does your cable connect directly or to one of those offset adapters?  If it connects directly you need a 38,39, or 40 tooth gear
Offline K5blaze454
  • 4x4 performance
« Reply #4 on: January 26, 2016, 10:51:11 am »
Yes 55 on my gps and 70 on factory speedo. It hooks directly to my transfer case tail shaft. No I haven't measured the tires exact. Thanks guys for you input and help. I hope we can solve this problem because my gps is not practical. And I like to get my fuel mileage on my new motor.
Offline K5blaze454
  • 4x4 performance
« Reply #5 on: January 26, 2016, 10:51:54 am »
1500 at 55
  • Wisconsin
« Reply #6 on: January 26, 2016, 03:28:47 pm »
20168/ Tire diameter (inches)= tire revolutions per mile
15 x 4.11 x tire rpm (answer from above) =
take the answer from above / 1001= # of teeth on driven gear
so if your tires are 32.5 inches...... 20168/32.5= 620.55
15 x 4.11 x 620.55= 38,256.9
38,256.9/1001=38.2   you would need a 38 tooth driven gear
You need to measure your tire height, Brooke's pickup is only 1 MPH off the GPS after doing this
in the formula above..... if anyone else wanted to use it, the #15 is the teeth on the drive gear, so would need to change to the # of teeth on your drive gear.
Offline rich weyand
« Reply #7 on: January 26, 2016, 03:35:24 pm »
Or you could put a 1:0.800  speedometer ratio adapter between the speedo cable and the transfer case.
