Author Topic: Where is the reverse light switch  (Read 3108 times)
Offline Mikeymike383
« on: January 28, 2016, 12:41:01 am »
Looking for reverse light switch on my c10 it a 73
383 stroke
Offline AZ87V10
Re: Where is the reverse light switch
« Reply #1 on: January 28, 2016, 01:24:29 am »
Automatic or manual trans? On an automatic its incorporated into the neutral safety switch and is on the bottom of the steering column inside the cab. If it's a manual, its a little screw in vacuum type looking switch on the trans itself.
Offline hatzie
« Reply #2 on: January 28, 2016, 08:22:01 am »
Three on the tree will be a switch thats's similar to the neutral safety switch for the automagic transmission at the bottom of the steering column.
