Author Topic: Delco Radio Speaker/Power Pinout  (Read 9541 times)
Offline BBM3
« on: January 29, 2016, 04:48:00 pm »
I have been unable to find connectors or more importantly the pinout for the Delco AM radio pictured below.
I don't really need connectors I have no problem slinging solder.
Thanks for looking.
Re: Delco Radio Speaker/Power Pinout
« Reply #1 on: January 29, 2016, 04:56:08 pm »
77 and older GM cars have those plug ins.  Ebay has them as well.
Offline BBM3
« Reply #2 on: January 29, 2016, 05:02:41 pm »
Thanks,
All I have been able to find on Ebay etc. are the rectangular blue, white, and black connectors which I am familiar with.
What I really need is the pinout for this radio.
« Reply #3 on: January 29, 2016, 05:04:39 pm »
this is a picture of the back of a AM 8-track stereo...  Rotate the plugs on the standard AM and you get the gist of it.
Offline hatzie
« Reply #4 on: January 29, 2016, 05:07:13 pm »
The pin-out for the radio will be in the factory wiring diagrams.  Look in my signature...
Offline BBM3
« Reply #5 on: January 29, 2016, 05:13:04 pm »
Thanks I hoped you would chime in.
I did download your service manual a couple of weeks ago.
I must have missed what I am looking for.
I'll read again.
Thank you!
Offline BBM3
« Reply #6 on: January 29, 2016, 05:14:22 pm »
Thanks that picture solves the power, ground, and backlight part.
Offline hatzie
« Reply #7 on: January 29, 2016, 05:34:33 pm »
I'll read again.
Thank you!
You need the wiring manual.  It's separate from the service manual.  If you snag em from my Mediafire bucket I have sub-folders for each year.
There are actually 3 or 4 manuals to make a set depending on the year.  1 Service, 2 Unit-Repair, 3 Wiring, and 4 Emissions/Driveability manuals.
The radio wiring will be toward the end of the wiring manual in the optional equipment sub-harness diagrams not on the base model overview wiring pages.
The actual connector family is Delphi Pak-Con.  Not sure if it's Pak Con I, II or, III.  Delphi still sells the terminals so you can buy em from Del-City etc but not these radio connector shells.  You can evilbay all of the 70's radio connectors with pigtails.
« Last Edit: January 29, 2016, 05:38:26 pm by hatzie »
Offline BBM3
« Reply #8 on: January 29, 2016, 05:52:46 pm »
I have the wiring manual as well.
I see the three pin power connector but not the speaker connectors.
I don't want to waste your time. I'll look further and figure it out. I'm sure it is all there.
If all else fails I can take the chassis apart and use the schematics in your radio service manual.
Thanks for sharing!
EDIT:
I am not sure if the Delco radio I have came from a 1975 truck.
It may well have come form an older GM vehicle?
Additionally, a previous owner cut the original radio wiring, dash, IP trim, and installed a single DIN no name Chinese POS radio.  >:(
I have a new IP trim panel and I am making a steel patch panel to fill the DIN hack job and allow me to install a period correct Delco two shaft radio.
« Last Edit: January 29, 2016, 06:36:45 pm by BBM3 »
Offline hatzie
« Reply #9 on: January 30, 2016, 06:24:10 am »
Try the upper left corner of page 10.
Offline BBM3
« Reply #10 on: January 31, 2016, 02:38:55 pm »
Exactly what I was looking for.
Thank you very much!
