Shift linkage issues
Topic: Shift linkage issues (Read 14792 times)
Re: Shift linkage issues
Reply #15 on:
February 12, 2016, 06:11:57 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32337.0
like this?
Justin84k10
Reply #16 on:
February 17, 2016, 07:09:06 am »
I purchased mine from Truck
2006 Gmc regular cab short bed 4.8 v8 daily driver
1984 Chevy k10 regular cab long bed plow truck
84 shorbed parts truck
A bunch of parts 80% of a truck. Have to put them together
Reply #17 on:
February 18, 2016, 12:12:49 am »
I've searched there and can't seam to find the ones I posted
Justin84k10
Reply #18 on:
February 19, 2016, 07:37:38 am »
The one I got is like a universal one that requires parts to be cut. I have been playing with the one on the truck a little and have got it to shift a little better. But their is still something not right with it and I'm just not sure what it is.
zieg85
Reply #19 on:
February 19, 2016, 07:44:02 am »
How good is your transmission mount? If it is original the trans/transfer case could be hanging lower causing it to bind...
gunrac
Reply #20 on:
February 19, 2016, 08:57:41 am »
Are all your body line's running even from front to back? I had a similar issue yrs. back. Cab mounts were shot. My problem was from the column rod down to tranny linkage. All being offset enough not to get the proper throw, as the cab dropped.
Never Apologize..........as it shows signs of weakness
Justin84k10
Reply #21 on:
February 22, 2016, 09:11:21 am »
My tranny mount seems to be in good shape. Not sure if it's original or not. The body lines of the truck are ok. It had been shifting fine and then all of the sudden it started to struggle getting into park and there is lots of play on the shifter when it's in reverse.
Reply #22 on:
February 22, 2016, 08:39:26 pm »
Pop the hood and inspect the rubber bushing on the steering column to the shifting linkage . Is there even one there?
Justin84k10
Reply #23 on:
February 24, 2016, 01:56:49 pm »
Here is what it looks like currently
Reply #24 on:
February 24, 2016, 02:06:26 pm »
from the pictures it looks good but is there play in it?
Justin84k10
Reply #25 on:
February 24, 2016, 07:39:42 pm »
Yes there is and everything is tight. In reverse the lever moves a little bit and when it's out on park it doesn't really move the selector on the tranny. I'm really stumped on what is wrong with it I'm staring to think that the cab may have moved or settled a little bit or something.
Justin84k10
Reply #26 on:
February 27, 2016, 12:15:55 pm »
Replaced the main rod that goes from the engine bay down to the transmission and it seems to shift fine now!
