Author Topic: Tci controller for 4l80e  (Read 12084 times)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Tci controller for 4l80e
« Reply #15 on: February 05, 2016, 07:40:34 am »
the preferred pump is AC-Delco EP158, specs are 9-14PSI, 22GPM, it is the stock pump for 1993 GMC/Chevy Turbo Diesels
it does require the special O-ring fittings, I solved by purchasing Dorman PN-800-170, just a 4 inch barbed fitting, so I could run rubber hose on either end
 1986 Chevy K30(under repair)
Offline fmxr47
« Reply #16 on: February 05, 2016, 07:25:22 pm »
Thanks for the info! Does anyone by chance know what ports are what on the ip and on the tank selector valve so I can scrap everything I don't need and just run a supply and return line for the passenger tank alone.
« Reply #17 on: February 05, 2016, 07:47:37 pm »
On the tank, there should be three fittings, one is 3/8"-this is the supply, one is 5/16"- this is return, one is 1/4"-this is for emissions and is really just a vent if the charcoal canister is gone. Normally one would block it and use a vented cap.
If you don't plan on using drivers side, just remove the fuel selector, and when you remove the extra lines everything should be self explanatory, the bigger lines are the supply,
As for engine side, there should be a 3/8" inlet into the fuel filter, then a 1/4 out to injection pump-located in center of all the hardlines. The return comes off a metal line- and depending on setup should either exit over passenger valve cover or to the rear of the engine, again passenger side in the valley(should be a 5/16" hose)
Offline fmxr47
« Reply #18 on: February 05, 2016, 07:52:04 pm »
Thanks a bunch for the help, I'll be looking at it tomorrow after some side work.
« Reply #19 on: February 06, 2016, 03:20:15 pm »
forgot we do have some manuals for the 6.2 and 6.5
here
Offline fmxr47
« Reply #20 on: February 07, 2016, 01:32:06 pm »
Thank you that was very helpful, I already have been reading a bunch of the manual
Offline fmxr47
« Reply #22 on: February 07, 2016, 04:30:12 pm »
Offline hatzie
« Reply #23 on: February 07, 2016, 10:31:46 pm »
working on getting these to the website also
6.5L  DIESEL/TURBO DIESEL  ELECTRICAL DIAGNOSIS  MANUAL SUPPLEMENT
http://www.mediafire.com/download/32q73jdfjpa3fh2/GMT9495DSLUD_1994_95_GM_P_1994_GM_CK_DIESEL_ELECTRICAL_DIAG_SUPPLEMENT.pdf
1994 6.5LTD EFI OBD
http://www.mediafire.com/download/7222nzp0kitv8nf/GM_STG_16015_15_2_1994_6_5L_V8_Turbo_Diesel_EFI_OBD_I.pdf
and for the 4l80e
http://www.mediafire.com/download/2o21d84ygmh6sdb/GM_STG_17021_24_Hydramatic_4L80E_TRANSMISSION_Electrical_Supplement.pdf
The main archive folder link worked.  Good.
That 6.5L textbook covers the 93 DS2 and 94-95 OBD 1.5 DS4.
I still need to scan the other 6.5L Diesel textbook for the 96 on up DS4 OBD II engines and the Oldsmobile 350 DX textbook.
Time time time...
My Droid from orbit
« Last Edit: February 07, 2016, 10:33:22 pm by hatzie »
