Interior & Equipment
Restoring door panels?
Topic: Restoring door panels? (Read 14943 times)
CA Big Red
February 06, 2016, 10:21:02 pm »
I've used the equivalent of bondo to touch up the top of the faded and dried out door panel on the passenger side and then painted the whole thing. That worked okay, but the bondo stuff kind of cracked and it wasn't the best. So, I'm looking for better ideas on how we bring these panels back. Any thoughts?
"You don't know what you don't know."
1978 Scottsdale Stepside
383 w/ 4" lift & 35" BFG
LTZ C20
Re: Restoring door panels?
February 07, 2016, 12:29:19 am »
Buy quality new ones lol
LTZ Cheyenne C20
CA Big Red
February 07, 2016, 10:49:56 am »
That would be great. Can you get these same door panels and install this trim back on? I thought the aftermarkets couldn't take the stock trim pieces back on?
LTZ C20
February 07, 2016, 01:34:44 pm »
Sí señor. New ones with provisions for the trim are available as well as all new trim pieces. Everything on that door panel is available new.
LTZ Cheyenne C20
CA Big Red
February 07, 2016, 03:05:44 pm »
Yep. I just looked them up. Set of red panels $199. I tackled this in 2011ish. Seen here and there wasn't the OEM panels at the time. From what I remember. This looked okay until the paint was scratched.
LTZ C20
February 07, 2016, 05:01:53 pm »
I think the pieces that come in the color you want are made of the correct color plastic. They aren't painted like if you just bought black pieces and painted to the desired color.
LTZ Cheyenne C20
OldGray
Ne'er-do-well
February 17, 2016, 11:50:46 am »
You can repair broken ABS plastic by using a mixture of ABS shavings and Acetone. I will post pics of the panels I am currently repairing in a separate thread soon.
Use an old piece of ABS plastic and bust it up or grind it into the smallest pieces you can. Put them in a glass jar and add about an equal amount of Acetone. Allow it to melt into a slurry - it may take a few hours - stir occasionally. Use it as a glue or filler, in layers. I occasionally use mesh fiberglass tape in between layers to add strength. The ABS slurry will melt into the old ABS and the bond will be as good (or better) than new.
Last Edit: February 18, 2016, 09:21:56 pm by OldGray
1979 Chevrolet Bonanza / 305 / LWB
OldGray
Ne'er-do-well
February 17, 2016, 03:12:35 pm »
I ran out and took a few pics of the door panels I recently repaired using the melted ABS trick.
(FYI - here is a thread I started about ABS repair -
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32666.0
The entire top strip of the panel (next to the window glass) had snapped off. I glued it back and reinforced it.
The screw holes in the door had broken out in a few places. This one has been repaired.
In the process of being painted a brighter red.
Last Edit: February 22, 2016, 12:48:50 pm by OldGray
CA Big Red
March 29, 2016, 10:30:32 pm »
LTZ I went with the new panels. Turned out great. Wish I had ordered the trim and new mirrors. Have since ordered both and will have to tear the passenger panel off when they arrive and then finish accordingly. Now I want to just paint the truck.
LTZ C20
March 29, 2016, 11:49:01 pm »
That looks great! Where did you end up getting them from? A few of the main more common restore companies have them.
LTZ Cheyenne C20
March 30, 2016, 08:19:56 am »
If you are wanting to restore them and paint them I would follow the above for repair and I would do the following for painting them.
http://73-87.com/7387garage/interior/vinyl_dye.htm
If the texture is gone, I "fix" them with bedliner like we did for the pillar pods.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=30672
CA Big Red
April 03, 2016, 05:50:36 pm »
LTZ I bought them from the place of which we do not speak...
LTZ C20
Reply #12 on:
April 03, 2016, 11:55:05 pm »
I figured lol. I'll get new panels one day eventually.
Last Edit: April 03, 2016, 11:56:50 pm by LTZ C20
LTZ Cheyenne C20
