Author Topic: Convert from power to manual steering  (Read 8432 times)
Offline mcintyrederek
  • Rookie
« on: February 13, 2016, 10:23:17 am »
Vehicle = 1986 C10 Silverado, with power steering, and originally had a 4.3 V6 in it.. TH400 trans.
Engine now = 350 but I'm sure that won't make a difference in my question.
I currently have power steering but the pump, hoses and "gearbox" assembly are all starting to leak.  Instead of rebuilding, I have thought about ditching the power steering altogether and go with regular old manual steering.
I can get my hands on some manual steering gearboxes fairly easy.  Does anyone see any problem with this, and will the manual gearbox use the same bolt pattern as the hydraulic box?  Will it pretty much be a direct swap?  Thanks..
Mack.
1986 C-10 Silverado 350 CI 260 HP, Edelbrock 1405, TH400, 2.73's - rescued from the junkyard - Farm Truck, daily driver!
Online zieg85
Re: Convert from power to manual steering
« Reply #1 on: February 13, 2016, 10:41:12 am »
Easy as changing the box and ditch the hoses and pump.  I've done this several times with ZERO issues.  I prefer the road feel of armstrong steering and it keeps folks from borrowing your truck.
  • Rookie
« Reply #2 on: February 13, 2016, 11:12:18 am »
That's the answer I was looking for.  THANK YOU.  P/S is nice on a street car but manual steering would be great on an old farm truck, and it's one less thing under the hood to leak or mess up.
Mack.
Online zieg85
« Reply #3 on: February 13, 2016, 11:19:42 am »
Unless you do a lot of parallel parking PS is not needed on a 2WD 1/2 ton.  You'll want the OEM sized steering wheel though...  1 less V-belt is a win-win
  • Rookie
« Reply #4 on: February 13, 2016, 01:21:07 pm »
Yep.  It has the factory steering wheel.
I don't have any problems replacing the gearbox, but how difficult it is it remove the steering arm from the spline shaft on the current P/S box?  It's not rusty-rusty but it's old and... you know how it is.  Soak everything in penetrating oil for a week before attempting to change?
Mack.
Online zieg85
« Reply #5 on: February 13, 2016, 03:05:55 pm »
I think the pitman arm is steering box specific.  In all cases mine had them on it already.  A quick search of any auto parts website to see if it lists the same part # should tell you.
Offline Rattler12
  • Old Geezer
« Reply #6 on: February 18, 2016, 06:12:42 pm »
Buy a pittman arm fork and a 2 pound sledge hammer and whack away
83 C-10 shorty 454, 5spd, 3:73 posi
