Author Topic: Window motor relay on 1978 2wd gmc jimmy  (Read 4680 times)
Offline Mikeymike383
« on: February 15, 2016, 08:17:24 pm »
Is there a relay on the 78 gmc jimmy 2wd 4 the electric Windows and door locks?
383 stroke
Offline LTZ C20
Re: Window motor relay on 1978 2wd gmc jimmy
« Reply #1 on: February 17, 2016, 12:01:21 am »
Yes.
LTZ Cheyenne C20
« Reply #2 on: February 17, 2016, 10:00:35 pm »
Where is it at I can't seem 2 find it
383 stroke
Offline LTZ C20
« Reply #3 on: February 19, 2016, 10:40:28 pm »
I believe it is under the drivers lower dash area, somewhere close to the fuse block or the middle dash area under the ash tray area.
LTZ Cheyenne C20
« Reply #4 on: February 23, 2016, 10:17:28 am »
Ya I found them they make a clicking sound but don't move the locks of Windows how likely is it that bout door locks and window motors are bad n my k5
383 stroke
Offline blazer74
« Reply #5 on: February 23, 2016, 11:00:39 am »
Pretty sure that relay is just for the locks. The windows use a circuit breaker plugged into fuse panel
« Reply #6 on: February 23, 2016, 07:12:44 pm »
Do u have a pic of where it goes
383 stroke
Offline LTZ C20
« Reply #7 on: February 23, 2016, 10:31:20 pm »
Only the locks use a relay, the windows use a circuit breaker as Blazer74 stated. However, adding a relay harness to the window wiring harness makes them work much better.
LTZ Cheyenne C20
