Author Topic: MY 1974 GMC HALF TON  (Read 35876 times)
Offline LTZ C20
Re: MY 1974 GMC HALF TON
« Reply #30 on: March 01, 2016, 03:04:25 pm »
Yea it's not to terrible. The fuel tank is a cake walk if even just the bed is off and not the cab, if both are off then it is a breeze. The cross member lines are only about as wide as the frame and go on the cross member just behind the bottom of the cab wall, easy peasy. If you can find a decent truck or a few with decent parts, you should have it made. Only thing I would get new if you even want to bother with new would be the valve itself and the switch in the dash of the cab. Unless the wires are damaged, a quick ohm test of the harness and even that could be reused.
LTZ Cheyenne C20
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #31 on: April 11, 2016, 12:14:26 am »
Sorry I haven't posted in a while guys, I've been busy with a Comercial job that we just recently finish up on. So pics will be coming back really soon.
Offline OldGray
  • Ne'er-do-well
« Reply #32 on: April 11, 2016, 12:23:37 pm »
You do very nice work!
1979 Chevrolet Bonanza / 305 / LWB
Offline bcstingray
« Reply #33 on: April 17, 2016, 04:06:59 pm »
After looking at your post, I liked the idea of using your motor hoist to lift the cab off the frame. that gave me the idea to use mine to lift the bed off the truck when I put a Suburban gas tank in my 73.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #34 on: April 19, 2016, 12:03:05 am »
Thanks for the support brutha!
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #35 on: April 19, 2016, 12:09:40 am »
I actually just removed the bed and used a 30 dollar 1 ton chain hoist from harbor frieght. I hung it off this old A frame welded pipe swing I had found years back. Was way easier than using the engine hoist. I have pics and I'll post them also as soon as I get a chance.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #36 on: April 21, 2016, 11:46:12 pm »
I hunted around town for this part and had no luck finding one. I had a long conversation with the speed shop tech at pep boys about the part though and was told the proportion valve rarely have to be replaced otherwise I'll have to order one off the web. So I decided to keep the original one clean it up and throw some paint on it
 Came out nice after being bolted on  8)
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #37 on: April 22, 2016, 12:10:45 am »
Took care of the motor mount brackets & they turned out really well with the paint job they got. I know they look different from what the original were and that's cause of the pontiac 455 it had in it and I know it ran with it in it already so I'm not going to worry about finding chevy 350 bracket. Anyways it came out awesome!
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #38 on: May 02, 2016, 12:07:52 am »
Doesn't look bad put together. Slowly things r getting bolted back on.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #39 on: May 02, 2016, 12:16:40 am »
Decided to go ahead and rebuild the steering box. I doubt it needs to be rebuilt but better to have it done since I have the truck torn apart.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #40 on: May 02, 2016, 12:24:54 am »
Got all the seals rings ect, also got the box torn apart. Sorry no pics of the new stuff installed due to all the wheel grease on my hands.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #41 on: May 05, 2016, 11:40:19 pm »
Couple of pics of the inside of the box.
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #42 on: May 05, 2016, 11:48:13 pm »
Pics of the box put back together and back on the frame with a nice paint job and all new seals on the inside.
Offline ttcfan4476
« Reply #43 on: June 15, 2016, 09:56:02 pm »
Nice work
Offline ROARING 455
  • STRANGE MUSIC!
« Reply #44 on: August 16, 2016, 09:44:09 pm »
Well shoot! >:( Anybody know where I can find this leaf spring only, I don't need all of them just this one. Thanks in advance.
