Author Topic: 1987 k10 305 tbi wont idle and the 700r4 transmission wont shift up  (Read 5108 times)
Offline Tylerbob7
I just bought the truck for $600. It sat for a couple years wen i got it but started up after some new gas and a little love, it wont idle on its own but once i get going it has no issues. It stopped shifting up yesterday after i tested the 4x4. It drove just fine for the 250 mile trip back from where i bought it, and now it wont shift up ( park, reverse, neutral work but it wont get out of first) i tried the reset button and it worked unril i came to a red light and wouldnt shift anymore. Any help on either issues would be greatly appreciated.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 1987 k10 305 tbi wont idle and the 700r4 transmission wont shift up
« Reply #1 on: February 18, 2016, 06:36:53 am »
Check fluid in tranny, if it's dark you may have burnt up the clutch pack. Normally due from misadjusted tv cable
I would check for intake leaks, then double check idle speed, too low will cause it to die coming to stops...or is this only when cold?
 1986 Chevy K30(under repair)
Offline Fairlane514
« Reply #2 on: February 18, 2016, 02:37:48 pm »
Check your TV cable by pulling it by hand in park several times, it may be stuck.  Also pull the governor out and make sure the valve inside moves freely.
Offline Littlered383
« Reply #3 on: February 18, 2016, 08:21:02 pm »
I would check for vacuum leaks. Start the truck and open the hood. Listen for a hissing sound. More than likely a vacuum line from the transmission to the intake manifold is leaking. Fix that and you will fix the idle and shift problem.
Sent from my HTC6525LVW using Tapatalk
« Reply #4 on: February 18, 2016, 08:40:04 pm »
what reset button? but the tbi can leak around the base plate, is your check engine light on?
does it come on when you first turn the key on?
Offline AZ87V10
« Reply #5 on: February 18, 2016, 10:11:09 pm »
That's what I was wondering? What reset button?! I've never heard of such a thing! Unless he's thinking of a fuel pump shut off switch like on a Ferd? I wish it was as simple to fix as hitting some reset button! Lol!
Offline Fairlane514
« Reply #6 on: February 19, 2016, 07:15:38 pm »
No vacuum lines on a 700R4....TH350 and 400, yes
Offline Tylerbob7
« Reply #7 on: February 29, 2016, 09:33:59 pm »
Its right behind the plate that the throttle cable and tv cable are on. I know its there because that's how i got home
