Author Topic: Help Needed: New window motor and switch only goes one way  (Read 57118 times)
Offline plik
« on: February 16, 2016, 10:38:37 pm »
Recently the window motor gave up the ghost.  I got the regulator out, and then had the good sense to test my new motor before putting the regulator back in.
Anyway, it only spun in one direction -- up.
I figured the switch was bad so I got a brand new switch and still only one direction -- up.
Passenger-side front window - 1984 Chevy Suburban
« Last Edit: February 16, 2016, 11:35:28 pm by plik »
Offline LTZ C20
Re: Help Needed: New window motor and switch only goes one way
« Reply #1 on: February 16, 2016, 10:50:03 pm »
The window motor spins in opposite directions depending on which way the switch is flipped because all it does is reverse the power ground feed, i.e. reverse polarity.
For example
Up = Left wire +POS, right wire -NEG
Down = Left wire -NEG, right wire +POS
The window motor electrical connector can only plugged in one way.
LTZ Cheyenne C20
Offline plik
« Reply #2 on: February 16, 2016, 11:30:02 pm »
Here is a video showing my troubles --
[youtube]https://www.youtube.com/watch?v=pDbztXhWG40[/youtube]
If installed, it would only roll the window up.
More info: I also can't make the motor move from the driver-side controls at all. :-(
« Last Edit: February 16, 2016, 11:33:00 pm by plik »
Offline LTZ C20
« Reply #3 on: February 16, 2016, 11:53:27 pm »
The drivers side routes power thru the passenger side switch. So it's possible for the drivers side to not work, be ok and the cause is a faulty passenger side switch. You could also not have any voltage coming from the drivers side, which isn't allowing the passenger side to use power as needed or the relay may not be working properly to divert power in the proper direction for the requested switch position.
LTZ Cheyenne C20
Offline plik
« Reply #4 on: February 17, 2016, 04:02:33 am »
So ... is the problem in the wiring connector that the switch plugs into?
I could easily imagine those wires getting loose in there.
What's the best fix for this?
« Last Edit: February 17, 2016, 10:10:02 am by plik »
Offline LTZ C20
« Reply #5 on: February 17, 2016, 03:10:42 pm »
You can buy new wiring harness pigtails. Waiting for another member to chime in here, you may need to do some voltage checks first.
LTZ Cheyenne C20
« Reply #6 on: February 17, 2016, 04:39:29 pm »
Assuming the left window functions, there is an open in the wiring between the driver and passenger side switches or the driver side switch is faulty.  If you unplug both switches and both window motors, you can use an ohmmeter to check continuity of the tan and dark blue/white wires from side-to-side.  If the wires of like color have continuity, the switch is faulty.  Otherwise, there is an open in the wire with no continuity.  Avoid connecting your meter to any pink wires since they attach to 12-volt ignition and serious meter damage can result.
Offline plik
« Reply #7 on: February 18, 2016, 10:12:09 am »
Thank you. I have a multimeter I can test with.
Offline plik
« Reply #8 on: February 18, 2016, 10:13:42 am »
Where can I buy such a replacement?
« Reply #9 on: February 18, 2016, 08:57:16 pm »
Delco PT-254 5-way for right door (GM 12101862)
Delco PT-546 6-way for left door (GM 12125634)
Both OEM connectors are available from www.rockauto.com, et al.
Offline LTZ C20
« Reply #10 on: February 18, 2016, 10:34:43 pm »
Well I'm gonna put my foot in my mouth now.....
LTZ Cheyenne C20
Offline plik
« Reply #11 on: February 18, 2016, 11:19:37 pm »
This is awesome! Thank you so much!
Two questions:
- I have a suburban, so the driver-side control uses a 10-pin pigtail. I don't think I need to replace the driver side; my question is about the passenger side switch -- is the passenger-side switch the same if the driver side uses a 4-switch control instead of a 2-switch control? It looks the same, I just want to make sure.
- For your right-door recommendation, will the same switch work for the passenger-side rear?
Thank you again!
Offline AZ87V10
« Reply #12 on: February 18, 2016, 11:35:04 pm »
Yes, it should be the same switch regardless as to whether it's on a truck, Blazer, or Suburban. The right side switch should be the same switch used on rear doors for Suburbans and crew cabs. The only switch that should be different would be the driver's side which should be a four door control, which is the same for crew cabs. I think bd just assumed you had a 2 door truck and not a 4 door Suburban.
Offline plik
« Reply #13 on: February 18, 2016, 11:55:40 pm »
Thanks! :-)
I found it a $1 cheaper on Amazon than RockAuto (weird, I know), and with free shipping at Amazon I bought it there. So, it's on its way. :D
Offline AZ87V10
« Reply #14 on: February 18, 2016, 11:58:40 pm »
Nice! Good luck on it and let us know how it turns out!
