Author Topic: 81 Tach Not Working  (Read 6344 times)
Offline williebm3
81 Tach Not Working
« on: February 19, 2016, 03:01:51 pm »
The tach in my 81 is not working. Looking for ideas on what it could be. When I turn on the key it registers about 500 RPM. Then once the engine starts the needle goes around clockwise and ends up straight down. Has a small resistor wired into it on the firewall, don't know if it is supposed to have this or not. Just looking for ideas on where to start.
Offline moss5472
Re: 81 Tach Not Working
« Reply #1 on: February 19, 2016, 06:06:06 pm »
you talking about an original tach in the cluster or an aftermarket tach?
84 k20 454 TH400
89 r2500
Offline moss5472
« Reply #2 on: February 19, 2016, 06:21:28 pm »
also did it used to work and now it doesnt or has it been like this since you got the truck?
84 k20 454 TH400
89 r2500
« Reply #3 on: February 19, 2016, 07:23:53 pm »
Assuming a factory tach, the "resistor" on the firewall is actually a filter.  You can bypass the filter temporarily to see if it makes any difference, but the problem is more likely in the tach head.  Begin by checking the wire connections to the back of the tach head and verify that the black ground wire makes a clean, tight connection to shiny cab sheetmetal.  The other tachometer wire colors are brown (the signal lead from the ignition coil) and pink (switched 12 volts that powers the tach head).  You can quick check the tach signal using a test light clipped to ground.  The test light will brighten slightly as engine RPM increases.  A quantitative test requires a primary triggered tachometer or an oscilloscope or a frequency meter.  Some DVOMs have an RPM tach function as well.  If all of the external wiring is healthy, the problem is in the tach head.  In some cases a visual inspection will show a burned component on the tach head circuit board that can be individually replaced if it can be positively identified.  It is not uncommon for resistors and diodes to fail.
Offline williebm3
« Reply #4 on: February 19, 2016, 08:13:36 pm »
This is the original tach. Have had truck for awhile and just got it going. Tach has done this since motor was put in it. Will have to check all of the wiring when I get time. Just had dash apart to replace cluster light bulbs. Should have checked it but did not have enough time so I will have to take it apart again. Clear cover needs changed anyway. So may wait until I can find a good replacement for it. Thanks.
« Reply #5 on: February 19, 2016, 08:35:37 pm »
To which distributor terminal does the tach wire connect?
Offline williebm3
« Reply #6 on: February 25, 2016, 07:05:24 pm »
Tach wire is going to tach terminal on distributor. Check wiring out and it all looked pretty good. Did not try the test light as I ran out of time.
