Author Topic: Front spring flip?  (Read 7698 times)
Offline Rocketbear
  • Churning n burnin
Front spring flip?
« on: February 25, 2016, 07:59:46 pm »
Got a lift question.....
So I got a 73 k20....I'm gonna use 4 inch blocks in rear and I'm looking at the front.... (I've never installed  lift before) what if you just flip the springs? They seemed arched downward.....if not what about just lengthining the shackles there attached too? ( I'm a steel fabricator n will be fabing my own parts) would either of these options work?
Truck doesn't really 4wheel much....but does haul weight time to time.......
Offline enaberif
Re: Front spring flip?
« Reply #1 on: February 25, 2016, 08:08:38 pm »
Neither option will work. Springs only work one way. If you want to lift the front then get proper lift springs.
It is the safest and easiest way.
Offline Rocketbear
  • Churning n burnin
« Reply #2 on: February 25, 2016, 08:28:20 pm »
Dang....allright...just making sure I wasn't missing anything
Offline enaberif
« Reply #3 on: February 25, 2016, 08:32:53 pm »
Stock springs are reverse arched to provide a smooth ride.
