Engine/Drivetrain
Can't shift to 1st gear with 4l80e swap.
Topic: Can't shift to 1st gear with 4l80e swap. (Read 4860 times)
Funkatation
February 29, 2016, 12:19:30 am »
I did my 4l80e swap some time ago and used the lokar linkage. I noticed going through the gears it doesn't go all the way to 1. Do I need a different column? I had a turbo 400 before.
frotosride
Re: Can't shift to 1st gear with 4l80e swap.
February 29, 2016, 02:09:52 pm »
Does the transmission actually shift into 1st gear when you put the shifter into its lowest setting and it's just not indicating it on the column? If so it is a simple adjustment to the selector detant cable to get the desired indication. Just remove the cover right below the steering column and you will see the clip and cable attached.
Funkatation
February 29, 2016, 09:00:29 pm »
It's hard to say. I have the Dakota digital gauges and the Gss 2000. When I went to program it, it wouldn't go down far enough on the column to get another gear. I'll check the suggestion though. Thanks!
enaberif
February 29, 2016, 09:05:09 pm »
Sounds like adjustment in the linkage either at the transmission or lokar needs adjustment.
March 02, 2016, 05:38:41 pm »
Quote from: enaberif on February 29, 2016, 09:05:09 pm
x2
Engine/Drivetrain
