Author Topic: Lowering the rear  (Read 6519 times)
Offline bcstingray
Lowering the rear
« on: March 02, 2016, 06:14:16 am »
Has anyone lowered just the rear of their truck using just the drop shackles to make their truck look level?
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Lowering the rear
« Reply #1 on: March 03, 2016, 04:09:30 pm »
I have never done it, but I know of one local truck that has drop shackles(they look to be about 1.5" longer) looks good, still has a slight rake that is barely noticeable, and figure it has to ride like stock. I have never talked to the owner, as I only normally see it when going going to the grocery store.
 1986 Chevy K30(under repair)
Offline figure843
« Reply #2 on: March 04, 2016, 12:59:44 am »
I have. I installed shackles in the rear to lower 2".  Truck sits level now. I also had to notch a piece out of my bed rail for clearance. Not a big deal though.
1984 SILVERADO LWB 350/400
1988 SILVERADO K5 BLAZER 350/700R4/NP208/3:73/6"RC LIFT/38.5/15/15 BOGGERS
Offline bcstingray
« Reply #3 on: March 04, 2016, 08:24:36 am »
Thanks. I'll be using the 2"drop shackles. Do you have any pics after you installed the shackles? My truck is a short bed.
Offline bcstingray
« Reply #4 on: April 20, 2016, 06:15:53 am »
Can someone post a pic of the notch they had to put in the bed rail when installing the drop shackles? I'm getting ready to install m shackles and don't want to cut to much out.
Offline bcstingray
« Reply #5 on: April 20, 2016, 07:57:38 pm »
Okay, I found the thread where the drop shackles were installed and showed a pic. It looked to be about 4" wide and 1.5" up.
