Author Topic: 86 TH400 to 78 sm465 swap help  (Read 6543 times)
Offline Hutch998
  • Squarebody Obsession
« on: March 03, 2016, 06:16:29 pm »
I recently saw a post on a truck page on facebook asking to swap their 465 for a th400. I happen to hate automatics, and have been wanting to swap for a while. The guy will give me the trans, np205 tcase and clutch pedal. Possibly the flywheel. I know I'd need driveshafts, but other than that, is there any super difficult modifications I'd have to make? I'm really in a bind with the knowledge to do this, as there are no guides on the internet particular to this swap. for an 86, do I have to cut the floor and make a bigger hump? or is that fine, and exactly how difficult is mounting the pedal and such? I dont think I'll have access to air tools, and probably not even a shop. I have most likely all the hand tools I'd need. Quick responses would be much appreciated! Thanks in advance!
78' K10
86' K20
94' K2500
Offline werewolfx13
Re: 86 TH400 to 78 sm465 swap help
« Reply #1 on: March 03, 2016, 11:24:51 pm »
If you have the low hump (which you shouldn't, with a 4x4), yes, you will have to switch to the tall hump. You will need the transmission (complete with the bell housing) clutch & brake pedal assembly, clutch pushrod, bellcrank, and adjuster. If you can, trace his trans tunnel cutouts onto a piece of cardboard to lay out a cut pattern on your tunnel.
Also, you'll need the proper flywheel for YOUR engine (86 used a 1 piece rear main, earlier used 2 piece). Also, pick up a new pilot bushing for your engine, and test fit it on the transmission shaft before installing. During your swap, you'll have to cut a hole in the floor pan for the clutch push rod. Your frame may or may not have the holes pre-drilled for the bellcrank to bolt to, as it would have been a hydraulic clutch in 86... I'm sure there are other things I'm forgetting, which is sad since I JUST finished my swap from a th350/np203 to an sm465/np205.
Good luck....that trans and tcase are HEAVY. I used an engine hoist through the removable trans tunnel in my 76 to lift it into place, and just had to wrestle it into position.
Chris
'83 Chevy c10 Silverado SWB
Offline Hutch998
« Reply #2 on: March 04, 2016, 11:42:35 am »
If I have the tall one, which I'm positive I do, otherwise the hump would be knee level, do I still need to cut it out and everything? or is it good for me to just swap it underneath and do the clutch stuff? Also, to get some opinions, should I go through with this deal, or get a nv4500? I have one in my 94 2500 and I really like it. Plus the mpg would be nice with it. Or is the sm465 better for mudding? This is also going to be a weekend drag truck, so speed and shifting is a big deal as well. Obviously the built th400 is best for that, but for the sake of a manual, which is best? And easiest and / or cheapest?
78' K10
86' K20
94' K2500
« Reply #3 on: March 10, 2016, 07:18:11 am »
ask no more
http://ck5.com/forums/resources/auto-th350-to-sm465-transmission-swap.32/
i know its a th350 to sm465 but you can manage  ;)
had this in the Transmission & Transfer case measurements plan on putting it in the tech section but not sure how accurate the numbers are
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: March 10, 2016, 07:25:12 am »
IMO, the sm465 is a slower shifter then the NV4500, neither are one you could really "speed shift"
 1986 Chevy K30(under repair)
