Author Topic: Install gas tank from long bed into a short bed  (Read 7480 times)
Offline haxsaw67
    • My YouTube Page
« on: March 04, 2016, 01:55:03 pm »
has anyone installed a long bed tank in a short bed truck? i want to have the 20 gal tank in my short bed truck..
1983 K10, GMC Sierra Classic, 5.3 Vortec Fuel injected motor w/ 70R4 transmission with OD. 14 bolt 1 ton axles w/ 4.10 gears and lockers, 6" Rough Country Lift, 35" Mickey Thompson Tires on Pro-comp Aluminum Wheels.
Offline LTZ C20
Re: Install gas tank from long bed into a short bed
« Reply #1 on: March 04, 2016, 02:56:24 pm »
They don't fit. Only 16 gallon tanks fit.
LTZ Cheyenne C20
Offline AZ87V10
« Reply #2 on: March 04, 2016, 03:19:39 pm »
What he said. They're too long to fit in between the wheel well and the cab floor drop down under the seat. Your only option is to try to install the factory dual tank set up if you only have a single tank, or remove your spare tire carrier underneath your bed and do the Blazer tank swap and still try to fab up a dual tank set up or eliminate the factory saddle tank entirely and do just the Blazer tank under the bed.
Offline LTZ C20
« Reply #3 on: March 04, 2016, 04:11:31 pm »
A factory duel tank would give you 2 16 gallon tanks, for 32 total. A blazer/suburban tank swap would give you 30-35 gallons I believe. Short bed tanks are 16 gallon only. Long he'd tanks are 20 gallon. 16g tanks fit on long and short beds, 20g tanks only fit on long beds.
LTZ Cheyenne C20
