Author Topic: Need a 12V source key on only:  (Read 3466 times)
Offline Stewart G Griffin
« on: March 05, 2016, 06:47:48 pm »
1) Does the BAT on the fuse panel mean it's always got power even when the ignition is turned off?
2) i'm trying to wire an electric fan using a relay. Could i just tap into something else like my aftermarket gauges (which i used one of the IGN terminals for which is one reason i don't have anymore IGN slots left open) since the toggle switch/and power to the relay isn't really going to consume that much power?
All 3 of my IGN slots are taken.
Offline blazer74
« Reply #1 on: March 05, 2016, 09:41:30 pm »
Sure you can, u can piggyback to power a relay.
I added a small aux fuse panel to power my added accessories.
Batt should be batt hot, check it with a meter or get a cheap test light.
« Last Edit: March 05, 2016, 09:44:53 pm by blazer74 »
Re: Need a 12V source key on only:
« Reply #2 on: March 06, 2016, 07:30:24 pm »
i wouldnt wire it into the ignition only type switch. i would go for something that has a thermostatic setting so at a certain temp it would kick on instead of as soon as you start it up
