Author Topic: '78 K20 Short Bed w/ Dual Exhaust and Rear Tank  (Read 8725 times)
Offline harcorshe
« on: March 07, 2016, 11:12:19 am »
I'm in the process of a short bed conversion for my '78 K20 with dual 20 gallon tanks and I can see that I will need to switch to 16 gallon tanks.
OR I was thinking about switching to a rear mounted 25 tank. My concern is the dual exhaust and if there is enough space to re-route the exhaust inside the frame rails, but still away from the gas tank. Does anyone have this setup? Any idea how far I need to keep the exhaust from the gas tank?
Here's a test fit of the short bed.
'78 K20
454
TH400
14 Bolt
205 Transfer Case
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: '78 K20 Short Bed w/ Dual Exhaust and Rear Tank
« Reply #1 on: March 07, 2016, 12:15:26 pm »
My Cherokee exhaust is about 2 inches away, I routinely see exhaust this close, add a heat shield for a little more peace of mind
 1986 Chevy K30(under repair)
« Reply #2 on: March 10, 2016, 07:46:50 am »
when i did the exhaust on my 86 i did 45° turn out right under the fuel tank. it was about a inch from the tank with no problems
