Author Topic: Cheap tie downs (and Spare Tire mount)!  (Read 4121 times)
Offline OldGray
  • Ne'er-do-well
« on: March 12, 2016, 09:16:14 pm »
Needed some tie-down points in my recently acquired truck, so I went down to the steel yard and bought a stick of 2" angle, 1/8" thick.  Also welded up a spare tire mount.  Total cost, about $24.
Painting
Spare mount
One of the (4) floor mounted tie downs
Under each top rail and a small one up front on the floor.
Added some squares of 1/8" steel underneath bed for added strength
Spare tire mount - still have to get a big bolt and drill the hole for it.
« Last Edit: March 14, 2016, 11:03:09 am by OldGray »
1979 Chevrolet Bonanza / 305 / LWB
Offline LTZ C20
Re: Cheap tie downs!
« Reply #1 on: March 12, 2016, 11:48:38 pm »
Not too bad. Putting them on the underside of the bed rails was a good idea.
LTZ Cheyenne C20
« Reply #2 on: March 13, 2016, 07:50:39 am »
just to give you an idea my truck has the tie downs on the side of the bed rail and a bolt every 5 or so inches. its rated for 1000 lbs
Offline OldGray
  • Ne'er-do-well
« Reply #3 on: March 13, 2016, 04:07:46 pm »
Finished up the Spare mount today.  Welded a short chain onto it so I can lock the wheel.
All done - and very solid!
