Author Topic: Can I rule out a bad turn signal switch? ('79 C10)  (Read 3399 times)
Offline Red Dog
« on: March 14, 2016, 02:18:01 pm »
Howdy folks,
I've been battling a left signal issue for about 2 weeks now.  I've looked at schematics,The bulbs, the grounds, etc.  When I throw my left signal, the REAR works perfect.  The front however does not.  It will work with 4ways no problem.  I've been told this is a ground issue but cannot find any bad grounds.  The signal and side market are not working.
Today I'm going to replace the socket assembly of the turn signal;  as a last ditch effort before tearing into the steering column.
On a side note, when I originally purchased the truck.  The Left REAR did not work either.  This was caused by one of those Walmart LEDS, I switched back to a regular bulb and the REAR signal works fine.  My front bulbs are good however.  s.o.s
Thanks
1979 C10 350/350 - RED DOG
Re: Can I rule out a bad turn signal switch? ('79 C10)
« Reply #1 on: March 14, 2016, 02:42:00 pm »
I've had switches go bad exactly as you describe.  I've switched steering columns before to find out the column I just put in, the switch was bad...
