Author Topic: SPEEDO DONT WORK  (Read 3570 times)
Offline kodalee
SPEEDO DONT WORK
« on: March 24, 2016, 09:05:16 am »
I just bought a 84 k10 and it was converted to a manual transmission. The speedo doesn't work were should I start to try and fix this. Anything will help.
Offline Eastonfrench
Re: SPEEDO DONT WORK
« Reply #1 on: March 24, 2016, 12:55:12 pm »
The speedometer system is simple. You have the gauge on your instrument cluster. In the back of it, there is a cable (think like a bicycle cable) plugged into the rear of it.  Said cable runs down and plugs in somewhere near the front end of your driveshaft. my truck is an automatic, and the cable is plugged into the top of my tranny. It should be easy to find.
Typically, the speedometer is either unplugged at either end, OR, the cable is broken somewhere.
1980 K10 - 350-Quadrajet-TH350-NP203
Offline VTK5Mudder
« Reply #2 on: April 02, 2016, 01:57:44 pm »
sounds about right Eastonfrench, I have heard some are two piece but its still the same hook up. easy fix , I need to replce one on my 79 GMC its bouncing and sticking heck ive been doing like 5mph and its said I'm doing 60 !
Offline rmuckey
« Reply #3 on: April 28, 2016, 12:41:46 am »
I had the same problem on my 75 K5. It was tough to figure out though, I started by replacing both the speedo and cable. I still had problems and then I was told that the triangular hole in the steel speedo gear that goes into the transfer case can round out. I ended up buying a new steel gear off of eBay and that solved the problem.
