Author Topic: Bench seat swap  (Read 82737 times)
Offline pasea
Bench seat swap
« on: March 25, 2016, 09:17:15 pm »
Finally got some decent seats to replace my broke bench seat.  I found back seat out of newer Tahoe and fabricated mounts to connect to factory bench seat holes .
« Last Edit: March 26, 2016, 09:48:05 am by pasea »
Re: Bench seat swap
« Reply #1 on: March 25, 2016, 09:23:32 pm »
Those look great.  Are they wide enough?  More pictures please
Offline pasea
Re: Bench seat swap
« Reply #2 on: March 25, 2016, 10:53:21 pm »
Yes exact same length as old bench was.  I think it was 56".
Offline FlatBlack77
Re: Bench seat swap
« Reply #3 on: March 26, 2016, 07:00:09 am »
wow thats sweet!!!
do they fold down too?
what year tahoe?
Offline pasea
Re: Bench seat swap
« Reply #4 on: March 26, 2016, 09:40:21 am »
wow thats sweet!!!
what year tahoe?
Yes, they fold down.  I'm not sure the year but i think is 2007 and up.
Offline LTZ C20
Re: Bench seat swap
« Reply #5 on: March 26, 2016, 11:06:36 am »
Those seats are from Tahoe, Suburban, Yukon and Yukon XL years 2007-2013.
The black leather also indicates they were from a vehicle that was optioned LTZ, SLT or special option LT2 or SLE2 with leather seats. Which means mid-level trim with additional cost for leather or high level trim with leather standard. SLE & SLT are GMC's codes for trim level.
« Last Edit: March 26, 2016, 11:10:50 am by LTZ C20 »
LTZ Cheyenne C20
Offline FlatBlack77
Re: Bench seat swap
« Reply #6 on: March 26, 2016, 06:17:17 pm »
so these also came in cloth? im not a fan of leather but with these seats i may have to make an exception if i can find a pair locally.
Offline LTZ C20
Re: Bench seat swap
« Reply #7 on: March 26, 2016, 10:34:06 pm »
Yes sir. Cloth seats are standard on LS/SL and LT/SLE models. These are the 2nd row seats that he used. The seats at the back doors. I would suggest using the front seats. These seats only fold forward for access to the 3rd row seats. Front seats, even if they are base model manual adjusting seats still have sliding forward/back, fold/recline and most usually also have one manual lumbar adjustment.
LTZ Cheyenne C20
Re: Bench seat swap
« Reply #8 on: March 27, 2016, 01:07:05 am »
how many tahoes and others dont have a center console?
Offline LTZ C20
Re: Bench seat swap
« Reply #9 on: March 27, 2016, 02:15:12 am »
The front seats have no console because they are bucket seats on LT/SLE models with the plastic center console that extends from the lower dash. LS/SL models with no full console have a small jump seat that folds down and doubles as an arm rest/cup holder. On models LT/SLE and up models with no console there is a jump seat that folds down also, it is an upgraded model from the LS/SL model fold down because it has 3 couples instead of only 2. It also has a large fold up arm rest that has storage in it and the lower part of the jump seat you sit on is openable & lockable with the ignition key and has storage in it as well.
The seats the poster used here are the middle seats so the only thing the middle seat does is fold down with a small arm rest and 2 cup holders but these seats are a 60/40 split bench and the middle seat is built in to the driver side unit. The passenger side seat is seperate to allow fold down access to the 3rd row seats.
The front seats on Tahoe/ Yukon, Suburban/Yukon XL and all models of trucks are the same. The 2nd row seats from a Tahoe or Suburban are completely different than the back seats on any crew or extended cab model trucks. The 3rd row seats on Tahoe and Suburban are completely different than any other seats for any of the other models.
LTZ Cheyenne C20
Offline impco lpg
Re: Bench seat swap
« Reply #10 on: March 28, 2016, 04:03:28 am »
COOL  THEY LOOK THE BIZZ  :)
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
Offline tgs30
Re: Bench seat swap
« Reply #11 on: June 18, 2018, 06:27:34 pm »
Do you still like these seats?  Anything you wish was different?  I'm about to pick up a set for my k10.
Sent from my Pixel 2 using Tapatalk
Offline ehjorten
Re: Bench seat swap
« Reply #12 on: June 18, 2018, 07:22:45 pm »
What is the deal with the plywood?  Did you make that up just to get the positioning of the seat correct and then make brackets to mount the seat?  the plywood goes away after the mounting brackets are made, is that correct?  Just trying to understand those pictures with the plywood.
-Erik-
Offline Da67goatman
  • Burban
Re: Bench seat swap
« Reply #13 on: June 19, 2018, 01:31:48 am »
Looks really nice.  Well done. ;D
<Pitcrew>
