Author Topic: double din install speaker upgrade  (Read 15750 times)
Offline impco lpg
« on: March 27, 2016, 03:27:12 pm »
hi all
been wanting to put a double din touch screen, with dash cam and reverse cam in my 1985 c10
http://www.ebay.co.uk/itm/130996182491?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
so after repairing my cracked dash top. and changing the color of my tan interior to sating black. i cut the opening in the front. the hardest part was fitting the cage in the wright position, with the dash in place. but it turned out sweet.
« Last Edit: March 27, 2016, 03:55:48 pm by impco lpg »
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
Offline impco lpg
Re: double din install speaker upgrade
« Reply #1 on: March 27, 2016, 03:31:28 pm »
it fitted
Offline impco lpg
« Reply #2 on: March 27, 2016, 03:43:53 pm »
finished off with my skull shifter
Offline Da67goatman
  • Burban
« Reply #3 on: March 28, 2016, 02:05:24 am »
Nicely done.  Different from most installs I've seen, but makes a lot of sense.  I like the aluminum trim strips.  No AC vents?
<Pitcrew>
Offline impco lpg
« Reply #4 on: March 28, 2016, 03:49:56 am »
the AC has been totally deleted (not needed in the uk) the strips i made out of polished stainless steel. you would never know that the interior was TAN. i also deleted the ash tray, need new carpet and black seat cover to finish.
« Last Edit: March 28, 2016, 04:10:59 am by impco lpg »
Offline firefighter
« Reply #5 on: March 28, 2016, 02:31:16 pm »
Very nicely done indeed!
I can tell you did a very methodical job.
Nothing like modern electronics in a not so modern truck.
You did a great job.   :)
Offline impco lpg
« Reply #6 on: March 29, 2016, 01:33:30 am »
thanks,
 just waiting for a 5" tft screen to come. which im going to mount where the rear view mirror is. and i will be using the reverse cam as a rear view mirror. will update when fitted.
 http://www.ebay.co.uk/itm/191823346455?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline OldGray
  • Ne'er-do-well
« Reply #7 on: March 29, 2016, 11:44:40 am »
Now that is cool!  Nice job.
1979 Chevrolet Bonanza / 305 / LWB
Offline impco lpg
« Reply #8 on: March 31, 2016, 01:54:32 pm »
the 5" tft monitor came today, fits perfectly where the rear view mirror was. it turns on with the ignition, i put the dash cam just under it, and doesn't look out of place. the screen has brightness/color/contrast av 1&2
the dash cam works on the head unit touch screen etc
« Last Edit: March 31, 2016, 02:23:35 pm by impco lpg »
