Author Topic: 79 big 10 k10 what do I have  (Read 10650 times)
Offline sb80514
Re: 79 big 10 k10 what do I have
« Reply #15 on: March 27, 2016, 08:50:29 pm »
Thanks guys for all your help so far I'm new to this forum and I am definitely a fan I will keep yall updated as I go with it I paid 1500 for it has bad motor fuel pump pump gas into motor thinning out oil I'm gunna try to keep the classic look with it only a 4 inch lift with narrow tires on the old steelies have 350 4 bolt main goin in next week true dual exhaust X pipe and super 40s to come as well and will be checking in to getting the ac working
Sent from my SM-N900T using Tapatalk
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #16 on: March 27, 2016, 09:27:07 pm »
Very nice, my brothers(well now my parts truck) was same way was definitely 1 ton, but the vin and glove box codes were all medium duty truck stuff(2.73 gearing 5 speed and two speed rear end)
 1986 Chevy K30(under repair)
Offline LTZ C20
« Reply #17 on: March 27, 2016, 11:34:51 pm »
Welcome. As many members have mentioned, it appears someone has done some moving of parts.
This is evident by:
1-the "big 10" sticker on the bed. As they mentioned, big 10 was for 2wd models only.
2-the front axle according to some members doesn't match for a 79, it does look correct for an earlier 70s model.
3-though the hood is correct for a 79-80 model truck, the grille and headlight bezels are not, they are 78 and earlier.
4-the dash trim, fender emblems, body side emblems(behind the door), door panels inside are all correct for late 70s.
LTZ Cheyenne C20
