Author Topic: 79 big 10 k10 what do I have  (Read 10665 times)
Offline sb80514
« on: March 27, 2016, 06:48:45 pm »
So I bought a 79 k10 the other day unmolested all stock except the granny 4 speed that I can tell has 350 granny 4 speed 205 trans case and 14 bolt rear with a dana 44 front from what I understand and can find I'm not seeing any 8 lug k10 4x4s and and I this front axle I thought had been takin out of production a few years earlier but I can tell it's factory truck has been sitting last 20 yrs and it's also the trailer ing special 9000 g.c.w also long bed factory ac and power windows locks and cruise I'm just not real sure what I have here it may be nothing it may be something and again it is a k10
Sent from my SM-N900T using Tapatalk
Offline Canadian 4X4
Re: 79 big 10 k10 what do I have
« Reply #1 on: March 27, 2016, 07:25:39 pm »
8 bolt axles means k20 with the dana 44 and 14 bolt
Offline sb80514
« Reply #2 on: March 27, 2016, 07:28:12 pm »
I understand that but it's not vins match title title says c10
Offline Jason S
« Reply #3 on: March 27, 2016, 07:31:53 pm »
It's hard to tell from the photo, but the front axle looks to be the earlier model D44 based on the hubs ('73-'77ish).  Sounds like a case of an axle swap with a 3/4-ton.
« Last Edit: March 27, 2016, 07:40:52 pm by Jason S »
« Reply #4 on: March 27, 2016, 07:34:46 pm »
probably swapped a good 1/2 ton body onto a 3/4 4x4 chassis and kept the half ton vin
Offline sb80514
« Reply #5 on: March 27, 2016, 07:36:18 pm »
That is very possible but I've gone over everything and it's jus so clean every nut and bolt it where it should be and the hubs on the 44 are huge
Offline sb80514
« Reply #6 on: March 27, 2016, 07:37:54 pm »
And the knuckles are flat top I'm going g to take better pics to post maybe tomorrow to help sort this out
Offline Jason S
« Reply #7 on: March 27, 2016, 07:42:33 pm »
Have you tried decoding the actual VIN to see if maybe the title is a typo?
The big hubs were used on 'early' 3/4-ton Dana 44's.
Offline sb80514
« Reply #8 on: March 27, 2016, 07:44:36 pm »
No I haven't not sure how to go about that I can post the Vin if someone can get something out of it
Offline Jason S
« Reply #9 on: March 27, 2016, 08:02:37 pm »
Look here http://www.73-87chevytrucks.com/VIN.htm and then scroll down to 1979. The file opens as a PDF.
See below for the jpeg.
« Last Edit: March 27, 2016, 08:06:07 pm by Jason S »
Offline sb80514
« Reply #10 on: March 27, 2016, 08:15:41 pm »
Ok so I guess it has been swapped I'm getting conventional cab with hd suspension In a 1/2 ton so I guess I just gotta good deal on someone else's hard work lucky me
Offline Jason S
« Reply #11 on: March 27, 2016, 08:23:57 pm »
Post your pics. We all love to see photos!
Offline sb80514
« Reply #12 on: March 27, 2016, 08:26:17 pm »
Offline sb80514
« Reply #13 on: March 27, 2016, 08:26:45 pm »
Will be posting more tomorrow
Offline AZ87V10
« Reply #14 on: March 27, 2016, 08:32:50 pm »
Big 10 was RPO code F44 and was only used on half ton 2 wheel drive trucks. It included things like bigger shocks and stouter suspension parts for an increased GVWR. It sounds to me like somebody in the past swapped a Big 10 body onto your K20 and ran with that VIN. Looks like your truck might be a mixture of parts. You have headlight bezels that are correct for 73 to 78 trucks, but have the correct 79 and 80 hood with the extra trim lip on the front! Still looks like a nice truck and all the major hard work has probably already been done for you!
