Author Topic: Full body restoration...  (Read 230456 times)
Re: Full body restoration...
« Reply #210 on: March 08, 2017, 05:29:31 pm »
Just get the VIN
« Reply #211 on: March 08, 2017, 06:26:50 pm »
The 4.8L is fine for a beater to me...
Offline LTZ C20
« Reply #212 on: March 09, 2017, 12:27:45 am »
if it looks good and the milage is low enough and it's a Z71, no reason it shouldn't be a good truck. There is nothing wrong with the 4.8L v8. For what you would use the truck for, it will suit you fine.
LTZ Cheyenne C20
« Reply #213 on: March 09, 2017, 07:04:56 am »
guessing its a 2000. the 6.0 afaik wasnt available in them. so you have the 4.3, 4.8 and 5.3. i would assume it came with the 5.3 all the z71 ive seen tahoes came with the 5.3 (nothing bigger) or crew cab with a 6.0
Offline philo_beddoe
  • 77 C-10
« Reply #214 on: March 09, 2017, 09:19:14 pm »
It is a 2000, zoom in on the windshield. Upper left corner. "00"
Sure wish it had the extended cab.
Offline LTZ C20
« Reply #215 on: March 09, 2017, 11:02:53 pm »
6.0s came in 3/4, 1 ton, Yukon denali , Sierra denali, Silverado SS, 1500 HD, Vortec Max, Cadillac Escalade models, some corvettes, SSR sport trucks and Silverado/ Tahoe Hybrids. if it's not one of those, it doesn't get a 6.0. I think that's all of them.
most likely that is a 4.8 or 5.3, being a 1500, short box standard cab, I would lean more towards 4.8. nothing wrong with it. there is only 1/2 a liter between the 5.3 and the 4.8, obviously not a huge jump. not worth the worry. you would never notice the difference between the two. remember a 4.8 = 289ci, 5.3 = 327ci, 6.0 = 383ci roughly. For comparison, the 6.6 Duramax would be a 400ci right? the old small block 400s were 6.6L, but the dmax is actually 396ci. An 8.1L is a 496ci, up a good jump from old 454s which are 7.4L.
so I wouldn't sweat the 4.8, if you don't have extensive experience with all of these engines, you will never notice a difference between 4.8, 5.3, 6.0, something.whatever or he says.she says. Hahaha. if you like it and it fits the bill, do it.
« Last Edit: March 09, 2017, 11:16:48 pm by LTZ C20 »
LTZ Cheyenne C20
« Reply #216 on: March 10, 2017, 04:45:24 am »
So then you should probably look for an extended cab or maybe an SUV? I love my Jeeps
  • 77 C-10
« Reply #217 on: March 10, 2017, 06:46:38 am »
In the process of wire brushing and cleaning up the frame. This part is on my leaf spring, noticed a little corroded, where can i get one? Couldnt find in catalogs.
« Last Edit: March 10, 2017, 07:30:57 am by philo_beddoe »
« Reply #218 on: March 10, 2017, 07:31:11 am »
i have a 4.8 and shes a dog granted it has over 200k but my buddy got an 02 back in 04 or something like that with a 4.8 and it could get out of its way but even he agrees theyre turds. im only getting 5.3 if its in a tahoe or a 6.0 or diesel in a crew cab. my truck Blue books for a little above 4k and to be honest i wouldnt pay 2.5k not even sure i would pay 2k
some specs
4.8
285 hp (213 kW) @ 5400 RPM SAE Certified
295 lb.-ft. (400 Nm) @ 4600 RPM SAE Certified
5.3
310 hp (231 kW) @ 5200 RPM SAE Certified
334 lb.-ft. (453 Nm) @ 4500 RPM SAE Certified
5.3 (2006+)
320 hp (239 kW) @ 5400 RPM SAE Certified
335 lb.-ft (454 Nm) @ 4000 RPM SAE Certified
« Last Edit: March 10, 2017, 07:36:02 am by Irish_Alley »
  • 77 C-10
« Reply #219 on: March 10, 2017, 07:35:17 am »
Right, i miss my 94 cherokee. However, i need a good size bed to fit 4 bikes in, and the extra cab or 4 doors for the two kids.
A 4 bike- rack seems a bit much, although they do make them. Hmm
  • 77 C-10
« Reply #220 on: March 10, 2017, 07:55:39 am »
They dont even show that leaf spring bracket here.  Its the sleeve i need the rest is fine. I can get the bolt anywhere.
« Reply #221 on: March 10, 2017, 08:10:01 am »
i would go to a spring shop for that. i dont think that catalog even has the center pin.
  • 77 C-10
« Reply #222 on: March 10, 2017, 08:10:55 am »
« Last Edit: March 10, 2017, 08:19:04 am by philo_beddoe »
« Reply #223 on: March 10, 2017, 08:27:24 am »
I have a bike rack that goes in the trailer hitch. Works mint
  • 77 C-10
« Reply #224 on: March 10, 2017, 09:50:18 am »
Yeah, the hitch mounted bike rack is the way to go for safety and strength. I'm familiar with the Cherokees, but what other models/years do you like and approve of?
« Last Edit: March 10, 2017, 04:06:10 pm by philo_beddoe »
