Author Topic: Headlight upgrade  (Read 8251 times)
Offline Jakethesnake73
Headlight upgrade
« on: April 05, 2016, 01:17:12 am »
Id just like to let anyone looking for headlight alternatives that the new jeep headlights will work with some modification. I got these led ones for my truck and the back of the light hits the light bucket so i had to bend back the metal on the bucket but they work great.
Offline LTZ C20
Re: Headlight upgrade
« Reply #1 on: April 05, 2016, 05:41:27 pm »
No pics of them on, hi & lo beams, DRL on?
LTZ Cheyenne C20
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: April 05, 2016, 05:52:41 pm »
I like it... Need a pic with power and brightness. I thought about doing the same thing for just my Hi beams on the quad light set up.
Headlight upgrade
« Reply #3 on: April 06, 2016, 08:04:10 am »
low beams
high beams low beams
I still need to get a pic from the cab of the lows and high beams going down the road.
Offline LTZ C20
« Reply #4 on: April 06, 2016, 02:37:53 pm »
Not to bad.
LTZ Cheyenne C20
Offline ehjorten
« Reply #5 on: April 07, 2016, 10:18:30 am »
The 2 artifacts (lighting spots) in the foreground...are those in the lamps or is it reflecting off of something?  They look like they are from the lamp beam pattern and it is a waste of light; you can't even see that light from the driver's position.
-Erik-
Offline LTZ C20
« Reply #6 on: April 07, 2016, 02:36:15 pm »
I think those are the DRL lights, in his link to amazon it stated they have DRL lights. Low brightness, for daytime visibility, usually aimed somewhat towards the ground and straight out, parallel to the ground.
LTZ Cheyenne C20
« Reply #7 on: April 11, 2016, 11:00:12 am »
the low beam and high beams plugged right in to the original harness on the truck. The parking lights had to be splice in to the marker lights. I didnt have those splice in yet in this pic. The parking lights do have a magnifying lense which i belive is reflecting the lights of the low beams making those spots
Offline redhot1.4
« Reply #8 on: October 14, 2016, 11:23:14 pm »
How much did these run you
Sent from my SAMSUNG-SM-G870A using Tapatalk
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #9 on: October 15, 2016, 07:51:38 am »
Those look pretty cool.
