Author Topic: Brake Rotor  (Read 3700 times)
Offline bcstingray
Brake Rotor
« on: April 09, 2016, 01:15:04 pm »
I'm in the process of changing the front brake caliper, hoses, rotors and pads on my 73. When I took the rotors off I found that it had the 1.25 inch rotors. The rotors I bought (before I took them off) were the 1 inch.
Does it matter if I use the 1"rotors?
Re: Brake Rotor
« Reply #1 on: April 09, 2016, 01:41:37 pm »
1" and 1.25" rotors are not interchangeable.
Brake Tech, what do all the numbers mean...
Offline bcstingray
Re: Brake Rotor
« Reply #2 on: April 09, 2016, 02:32:53 pm »
Thanks. The rotors I took off have a groove on both sides of the rotor. I've never seen this before. The grooves are in the same spot on each rotor.
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
Re: Brake Rotor
« Reply #3 on: April 09, 2016, 03:58:39 pm »
If the grooves are identical in both rotors and they are almost in the middle of the pad surface on the rotor GM has put a single groove in rotors in the past.
Offline bcstingray
Re: Brake Rotor
« Reply #4 on: April 09, 2016, 05:58:32 pm »
Like these?
Re: Brake Rotor
« Reply #5 on: April 09, 2016, 07:32:53 pm »
Those grooves are machined by the manufacturer.
