Author Topic: Fitting an earlier 73 front to the later 81 up truck  (Read 8399 times)
Offline vroomy
« on: April 12, 2016, 08:34:42 pm »
Hi new to the forum, looking into buying a short bed pickup. Only ones I seem to find rust free are the 81 and up but I much prefer the older 73 front. I know there is a lot of thread posted with people fitting the later front to the older pickup and it looks way too involved for my liking. My question is has anyone done the opposite and put the 73 front clip on the 81+? Is it any easier as far as fab work? Or does it still involve cutting etc?
Offline rcollamore
Re: Fitting an earlier 73 front to the later 81 up truck
« Reply #1 on: April 13, 2016, 04:42:19 am »
Yes i have 76 front clip on my 87 Suburban also changed the hood to a 76 it was really easy.
Offline XrayTedd
« Reply #2 on: April 13, 2016, 07:59:56 am »
I'm gonna be looking to do this with my 87 k5. Basically I'll need everything from the fire wall forward. Correct?
Sent from my SAMSUNG-SM-G900A using Tapatalk
"Till the wheels fall off"
Offline rcollamore
« Reply #3 on: April 16, 2016, 07:37:39 pm »
That is correct
« Reply #4 on: April 17, 2016, 06:52:26 am »
Everything from the fire wall forward. Including the windshield wiper stubs.
Offline FlatBlack77
« Reply #5 on: April 17, 2016, 07:58:58 am »
does this include radiators? or will the newer radiator fit the older front end
« Reply #6 on: April 17, 2016, 08:44:50 am »
Physically yes but depending on your set up the threaded holes to mount the radiator/shroud may not be there.  I've also heard the core support frame mounts need to be moved some.
« Reply #7 on: May 01, 2016, 06:38:28 am »
As far as radiator goes there are several different top mount set ups. You might have to mix, and match some parts.
Offline paulmflores
« Reply #8 on: June 05, 2016, 03:00:57 pm »
Ok I want to do thensame thing. Have a core support and grill headlight rings etc. Bottom valance. Will it fit between the 84 fenders?? Fabing radaror supports etc. Wont be much of an issue if I have to. Wanted a smoother no gap look there anyway.
Offline big_al273
« Reply #9 on: June 05, 2016, 06:16:12 pm »
70's is 70's, 80's is 80's you cannot mix and match between them without custom fab work, however the three different grilles in the 80's (single head light, dual stacked lights, and dual side by side lights) can be interchanged if you change to the appropriate rad cradle/core support without swapping fenders or hood
91 Chevy R3500 Crewcab future project
89 GMC R3500 Cab & Chassis Tool truck project
88 Chevy V30 Crewcab Ex-firetruck
87 Chevy R20 Crewcab future project
84 Chevy C10 Suburban Project
84 GMC K1500 winter beater
« Reply #10 on: June 14, 2016, 07:47:42 pm »
You DO NOT need to move the core support mounts on the frame.
As said already you will need EVERYTHING from the doors forward, including the windshield wiper stubs. If your truck is the two head light system the wire harness will work with the older round head light nose.
