Author Topic: 1973 chevy 4x4 cab swap  (Read 5092 times)
Offline 989kkzx
« on: April 14, 2016, 10:12:41 pm »
hi i am new to the form and was wondering what years of chevy cabs will fit a 73 chevy 3/4 ton  4x4  frame? the one i have now has a manual transmission so if i get a cab that had a auto in it will it be hard to convert it to a manual trans? any help will be great thank you
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: 1973 chevy 4x4 cab swap
« Reply #1 on: April 15, 2016, 06:01:03 am »
Any year cab will work, the only cab that will require some work is the low center hump 2wd auto cab, auto 4x4, manual 2wd, and manual 4x4 all had the high center hump
 1986 Chevy K30(under repair)
Offline Austin4wd
« Reply #2 on: April 15, 2016, 10:24:23 am »
Exactly. Had a similar problem in a 82 K5 2wd I was building. I couldn't find a low hump for it
'88 K5 Blazer (daily)
'80 K10 Sierra Grande (restoration)
'80 K20 Sierra Grande (Duramax swap0
'93 C10 Silverado (future build)
'90 Cavalier (RWD SBC swap in mind)
« Reply #3 on: April 20, 2016, 09:37:28 am »
you also have to use the body mounts for the frame not the cab
