Author Topic: trans question  (Read 3420 times)
Offline bob75
trans question
« on: April 14, 2016, 11:05:54 pm »
ok   here is the deal. I recently was given n 89 blazer. stock 350 700r trans. but the person who gave it to me took out the tbi and switched it to a carb, ruining the tbi harness along the way. I want to use the running gear in another truck. can I run the stock computer with the trans so all the shifting works,or will not having the tbi effect that function
Offline LTZ C20
Re: trans question
« Reply #1 on: April 15, 2016, 12:19:27 am »
The only things monitored/controlled by the ecm for the transmission are the vehicle speed sensor (VSS) singal, torque converter clutch  (TCC) lock up and what gear your in at any given time which is to helps determine if the TCC will engage because it will only come on in 4th gear, sometimes 3rd, depending on the setup. All most all of the ecm's functions are to monitor and control the engine. Shifting is done via internal transmission components in conjuction with the throttle valve (TV) cable. These inputs can be mimicked to use the trans as a stand alone unit without needing to involve anything for engine control/monitoring.
LTZ Cheyenne C20
Offline bob75
Re: trans question
« Reply #2 on: April 15, 2016, 11:44:32 pm »
so in simple terms......
Offline XrayTedd
Re: trans question
« Reply #3 on: April 16, 2016, 09:36:32 am »
No computer needed...
Sent from my SAMSUNG-SM-G900A using Tapatalk
"Till the wheels fall off"
Offline LTZ C20
Re: trans question
« Reply #4 on: April 16, 2016, 01:09:47 pm »
Exactly. You can fake the inputs with individual devices to use the trans by itself. No computer or TBI parts needed.
LTZ Cheyenne C20
