Plug wires
Topic: Plug wires (Read 3058 times)
1985gmc1500
Plug wires
April 16, 2016, 01:18:29 pm »
Hi The stock spark plug wires on my 1985 GMC Sierra 305ci are 8mm. I am running the wires via looms that bolt onto the valve covers. Since this is not the original wire routing the stock plugs you can buy will not fit correctly I am looking for red wires that I can cut to my own length and will fit on the stock distributor. I can not find these in 8mm would it be ok to use the 8.5 mm that msd sells?
bd
Re: Plug wires
April 16, 2016, 01:36:00 pm »
Using 8.5 mm MSD wires is fine, but first make sure the loom clamps will accept the larger diameter wire. I also recommend MSD's terminal crimpers, or similar, to properly crimp and permanently secure the ends without damage.
LTZ C20
Re: Plug wires
April 16, 2016, 02:16:51 pm »
I used the 8.5mm MSD red wires you speak of. I cut and crimped every single terminal my self using terminal tool WT 105 from Matco tools. They are good quality. I even used the extra wire and made a spark plug wire test wire for problem diagnosis.
LTZ Cheyenne C20
Jim_Hensley
Re: Plug wires
April 18, 2016, 12:00:52 pm »
the mm size really doesnt matter, it just thicker insulation, More of a marketing gimmick,
Plug wires
