Author Topic: Brake booster hiss  (Read 5299 times)
Offline bcstingray
Brake booster hiss
« on: April 17, 2016, 03:42:06 pm »
The power brake booster I have, used but was to be a good one, has a hiss coming from the back side inside the cab. My truck is a 73 that I switched from manual to power brakes using an 81 up booster. I take it its just bad. Anyone else come across this problem?
Re: Brake booster hiss
« Reply #1 on: April 17, 2016, 04:01:07 pm »
A continuous hissing sound from the booster is a perforated diaphragm.  Temporarily remove and cap the vacuum hose that connects to the booster then start the engine.  If the hissing stops, replace the booster.
Offline bcstingray
« Reply #2 on: April 17, 2016, 04:15:44 pm »
I'm pretty sure it's bad. Will the rod that attaches from the brake pedal to the booster rod (81 up booster) fit on a 73-80 booster?
Offline bcstingray
« Reply #3 on: April 19, 2016, 08:25:45 am »
Would it matter to put a JB5 booster on a JB3 system?
« Reply #4 on: April 19, 2016, 12:07:19 pm »
Using a dual-diaphragm vacuum booster is a common upgrade.
