Author Topic: suicide doors on stock hinges  (Read 7481 times)
Offline shaved80
« on: August 12, 2005, 06:32:00 pm »
i remember reading in a streettrucks mag that it's better (and cheaper) to use the stock hinges when suiciding doors, because they have that stock look of tucking inside instead of swinging out. is it possible to do this with our hinges? any places on the internet have a how to?
Offline roundedline
Re: suicide doors on stock hinges
« Reply #1 on: August 15, 2005, 02:53:00 pm »
Not going to be possible with the 73-87 hinges.  They mount perpendicular to the door at the front (like and L ) where they need to mount parallel.  I have heard Jeep Cherokee hinges work well for this application though.
Here is another website with this done on a 67-72:
www.suicided.com/suicidedoor1.htm
here is another done on a 88-98:
www.fullsizechevy.com/for...p?t=113656
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline shaved80
« Reply #2 on: August 16, 2005, 03:35:00 am »
i guess i'll have to buy the kit then >D
i could use the same striker/latches though right? just move the passenger assembly to the drivers, vice versa? (with some slight modification to hold the striker of course)
Edited by: shaved80 at: 8/16/05 3:02 am
Offline roundedline
« Reply #3 on: August 16, 2005, 10:16:00 am »
Yeah, you could probably use the stock pieces by swapping them.  Or you could use some Bear claw latches.
Project Su
Jimmy 2WD Project
Offline shaved80
« Reply #4 on: January 07, 2006, 04:08:00 pm »
it's possible to use cherokee hinges on a truck? i think that would look alot cleaner than the kits
Offline roundedline
« Reply #5 on: January 09, 2006, 10:25:00 am »
I haven't looked into it, but I guess anything is possible with time and ingenuity.
Project Su
Jimmy 2WD Project
