Author Topic: 305/Edelbrock 1411 adapter gasket help  (Read 2634 times)
Offline SquareBody86
« on: April 24, 2016, 11:47:03 pm »
Right so I've noticed after letting my truck run and warm up a bit that when I shut it off I notice some what I'd have to call smoke coming from the gasket that's between the intake manifold and the carb adapter. At the top of the gasket you can see a small section that's blackened where the smoke's coming from. Is this a heat insulator gasket or some over kind I need to get? I already planned on replacing the carb/adapter gasket to be on the safe side but I'm not sure what one the adapter/manifold gasket is.
If it ain't broke don't fix it, upgrade it!
'Rusty' 1986 C10 Chevy Silverado, long box fleetside, LG4 305/TH700R4 with Edelbrock 1406, 2.73 rear ratio
Re: 305/Edelbrock 1411 adapter gasket help
« Reply #1 on: April 28, 2016, 06:07:04 pm »
i think you just need a new carb base gasket. can pick them up at the parts store, not 100 % sure if i understand you right but the "black" part of the gasket can be fuel seeping out and if you have that big of a leak you will have poor running conditions also due to a large vacuum leak
