Author Topic: Changing the color of my interior?  (Read 8923 times)
Offline Barraphernalia
« on: June 24, 2005, 11:53:00 am »
I considering changing my 85 interior from red to black and would like see what others think.
I know I'll need new carpet and seatbelts, have to have my seats reapolstered and will have to have the interior metal that shows repainted, but can I paint my existing plastic pieces (moldings, door panels and dashpad) black?
Would it look the same as having black plastics from the start?
Would there be any feel or durability issues?
Offline Twofocused
Re: Changing the color of my interior?
« Reply #1 on: June 24, 2005, 01:45:00 pm »
I am not a fan of red interiors.
If the exterior is red I would not paint the interior metel pieces, just leave them red, that will look ok, red goes well with black.
As far as painting the vinal pieces like door panels, that looks ok if the panels are in good shape.  Otherwise just buy new, they are pretty inexpensive.
Its cheaper to find a j-yard black seat than it is to have your red one redone.
Get a JC Whitney truck catalog.
« Reply #2 on: June 25, 2005, 01:59:00 pm »
The interior metal should be the same color as the exterior body. As far as plastic & vinyl interior parts go if you use the correct materials such as SEM brand interior dye or = and prep it correctly they should look fine. You can get the dye in a spray bomb or by the quart or gallon and run it through a spay gun. As far as the seat goes you can buy a factory replacement cover, hog rings, and a par of hog ring plyers and recover it yourself. If your seat and  / or rug is in perfect condition you can dye them as well.
Seatbelts?
« Reply #3 on: November 30, 2005, 03:34:00 pm »
85 Silverado - SWB - 2WD
Changing interior from red to black.
Okay, I'm straightened out on not painting the interior metal. Not sure what I was thinking.
I'm all set with everything I need except the Seatbelts.  , Chevy Duty and JC Whitney only seem to carry generic assemblies. Is there any other option besides salvage or dealer parts department?
Thanks,
Barry
Shoulder Belts
« Reply #4 on: November 30, 2005, 03:38:00 pm »
Sorry, I forgot to mention; I have shoulder belts, not lap belts.
Offline roundedline
Re: Shoulder Belts
« Reply #5 on: November 30, 2005, 03:57:00 pm »
If you want it to be correct, you only options is salvage yards.
SSnake Oyl will redo seatbelts to original (any color) if you supply a working set.  This is their website: ssnake-oyl.com/
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline bigblock73
  • Yeller
Re: Shoulder Belts
« Reply #6 on: December 01, 2005, 11:43:00 am »
Check this out if you need help dying your plastic pieces
www.73-87.com/7387garage/...yl_dye.htm
...Jeff
'73 swb 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Thanks
« Reply #7 on: December 02, 2005, 09:09:00 am »
Thanks for telling about 73-87.com.
There's some great Stuff on there.
