Author Topic: What is wrong with this picture?  (Read 17213 times)
Offline Engineer
« on: May 03, 2016, 09:03:33 pm »
My wife figured it out right away and she never went with me when I pulled vans, she only went with me in my flatbed days.
Anyone?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline FlatBlack77
Re: What is wrong with this picture?
« Reply #1 on: May 03, 2016, 10:22:44 pm »
the plate that goes in the bottom left hand corner plate holder is missing? if i am not mistaken it identifies the hazards contained in the unit.
my only guess
Offline LTZ C20
« Reply #2 on: May 03, 2016, 10:33:42 pm »
my only guess
I thought of that too but if it has no hazardous materials on board I believe you don't need a hazard label.
LTZ Cheyenne C20
Offline FlatBlack77
« Reply #3 on: May 03, 2016, 10:51:26 pm »
is it missing a hows my driving sticker?
Offline travisr1988
« Reply #4 on: May 03, 2016, 11:11:16 pm »
Iirc the plate in the lower left identifying hazards is required to have something there stating non-hazardous if there are no hazardous products on board.
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Offline LTZ C20
« Reply #5 on: May 03, 2016, 11:15:10 pm »
Well that blows holes in my theory.
LTZ Cheyenne C20
Offline Engineer
« Reply #6 on: May 04, 2016, 06:41:21 am »
Here is a little hint:
The problem isn't with the load or anything associated with what could be inside the trailer. The problem is something that would indicate that there is a rookie hand on the other end of the trailer.
Offline Engineer
« Reply #7 on: May 04, 2016, 06:46:37 am »
Federal law was changed a few years ago that forbids the "Drive Safely" placard in the placard holder. The reason being is the idea that when responding to an accident the "Drive Safely" placard could misidentify the load to first responders and law enforcement. The new law only allows identification of haz-mat when a hazardous substance is present in a quantity that is sufficient to require placards.
Basically the new directive is intended to communicate "no placard, no haz-mat".
« Reply #8 on: May 04, 2016, 07:35:40 am »
does it have to do with the locks?
Offline Engineer
« Reply #9 on: May 04, 2016, 07:55:25 am »
It very well could.
Depending on your screen resolution you may not be able to see that one is a seal and the other is a padlock.
Offline travisr1988
« Reply #10 on: May 04, 2016, 10:22:21 am »
^ah, my screen resolution must not be good because all I saw there were blurs lol
Offline LTZ C20
« Reply #11 on: May 04, 2016, 01:03:18 pm »
My screen resolution it's really good but when zoomed in, it's still not clear enough to tell. One door latch has a pad lock and one has a seal? As in weather seal or harbor seal? Haha
LTZ Cheyenne C20
Offline Captain Swampy
  • Wisconsin
« Reply #12 on: May 04, 2016, 01:13:47 pm »
They both need to be on the right door then. The left door won't open until the right one does. Would have needed to zoom in to see that though.
« Reply #13 on: May 04, 2016, 01:34:37 pm »
i was leaving it for someone else but i think the lock is on the left side and the seal is on the right
Offline Engineer
« Reply #14 on: May 04, 2016, 05:30:37 pm »
The deal is the shipper's seal is on the right hand door......where it should be. Its presence to the consignee indicates that the load remains untouched since its leaving the shipper. The seal can easily be pulled off with your bare hands. The reason shippers put the seal on the right hand door is because the left hand door can't be opened until the right hand door is opened first.
Placing the lock on the left hand door does not prevent someone from tearing the seal off and opening the right hand door. By doing this you have access to the inside of the trailer. It is pointless to put a padlock on the left hand door.......unless what you are hauling is too large to fit through just one door.
If this driver keeps this practice up sooner or later he will have things stolen.
