Author Topic: 86 C10 305 header options?  (Read 36044 times)
Offline SquareBody86
« on: May 08, 2016, 11:11:07 am »
Something that's been on the list for some time now is exhaust work, whats on Ol' Rusty right now is completely roached out and since most of it is held up with chicken wire it needs to get done soon. Since I'm going to have to have the whole exhaust redone anyways I figured then would be a good time to do myself a favor and get some decent headers on, nothing super expensive I just need something that'll help my 305 breath and generally run better.
When I get it done at the local muffler shop I plan on having 3" exhaust put on, from what I've read 3" seems pretty good for a 305 and please don't kill me but I'm going to have stacks done with a good set of flowmasters. They will be true dual stacks and yes I know stacks on a gasser is like is equivalent to lightly a bible on fire around here but I plan on swapping in a 88-93 6.2l Detroit later on down the road and I planned on having stacks for that anyways so doing it now will save me a bit of bother later on down the road.
But yes any help/input on this is greatly appreciated.
If it ain't broke don't fix it, upgrade it!
'Rusty' 1986 C10 Chevy Silverado, long box fleetside, LG4 305/TH700R4 with Edelbrock 1406, 2.73 rear ratio
Offline Stewart G Griffin
Re: 86 C10 305 header options?
« Reply #1 on: May 09, 2016, 08:13:51 am »
3" might be too big for a 305 and the performance might actually go down.
My main concerns with headers for a street driven vehicle are: 1)will they last,  2) will the bolts stay tight, 3) It's now going to be much hotter underhood, how are you going to handle that?, 4) how will the plug wires, and other accessories be routed?
Some of the reasons why i haven't made the switch to headers yet.
Offline Rattler12
  • Old Geezer
« Reply #2 on: May 09, 2016, 08:17:41 am »
Neither have I........mainly cause they are noisier than the cast iron manifolds along with all the reasons you've given
83 C-10 shorty 454, 5spd, 3:73 posi
« Reply #3 on: May 09, 2016, 12:48:05 pm »
I guess that makes sense, I could see long headers causing the heat issue, would shorty's or hugger headers be better when it comes to heat? when it comes to side would 2.5" be better then?
« Reply #4 on: May 09, 2016, 05:47:56 pm »
Don't really have time to get into it now.
Why did you originally want 3" ?
And i'm not saying headers won't work on the street, because there are plenty of folks running them.   i had a car with headers and it worked ok, but they were already installed when i bought the car.
« Reply #5 on: May 09, 2016, 05:48:45 pm »
That too---they are louder.  Of course some people love that.
« Reply #6 on: May 09, 2016, 08:46:07 pm »
Was originally thinking 3" cause when I was reading around to see what is a good size for a 305 3" was one I saw come up.
« Reply #7 on: May 10, 2016, 05:53:26 pm »
i'm not saying DON'T go 3", thought there was another reason besides you read somewhere.
Don't have time to get into it now, maybe this weekend.  But i'm not an exhaust expert either.
« Reply #8 on: May 10, 2016, 06:52:18 pm »
ah its alright man we're all busy nowadays
« Reply #9 on: May 11, 2016, 05:30:30 pm »
not exhaust expert but i do like to do math or try.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=32901.msg279542#msg279542
maybe close to 120-130 hp from the factory.
so that 130/hp only needs 2" single or 1.85" dual
if you go too big you lose savaging effect of the exhaust which helps pull the exhaust from the cylinder for the engines next cycle
but this might help you better
http://www.hotrod.com/how-to/engine/ccrp-9903-305-chevy-small-block-engine-build/
« Reply #10 on: May 11, 2016, 08:48:08 pm »
Your a bit low there, it's actually around 150-165hp, the LG4's range from 150-170hp but I'm fairly sure this one is around 1985 and back the LG4's got a boost to 165hp in 85. Plus the edelbrock 1411 gives it a bit as well.
Offline teamcurtis
  • dangerous mechanic
« Reply #11 on: May 12, 2016, 01:07:53 pm »
i agree that 3" would be overkill for a 305, unless you are REALLY opened up the breathing on the other end and are looking to make high RMP horsepower
If you're going to swap to a 6.2  down the road, i would just wait on doing anything too fancy on the exhaust now. i cant imagine what will work well on your 305 is gonna be close to what will work on a 372... youll likely end up scrapping the whole thing anyway
1978 C10 Short Bed
350 smogged for CA
Offline DustyRusty
« Reply #12 on: May 12, 2016, 02:42:42 pm »
I agree with teamcurtis.  Don't get too fancy.  Here's what I'd do and have done:  Find a set of long-tube headers (4-into-one, or 4-into-2-into-1; stay away from shorties or block huggers unless you find them inexpensively), use 2" exhaust pipe for your exhaust, turbo mufflers which are low cost, and have your exhaust turn down and dump either right before or right after the rear axle.
Muffler shops usually charge by the foot for the pipe and by the number of bends plus labor.  The above-described system should be very cost effective.  By keeping it simple, you should still get a good and effective exhaust system at a good price.  Save your coin for an upgraded system for your 6.2 swap.
If you think the slight increase in noise from the headers is objectionable and there is too much heat from the headers, you can wrap the headers with that high-dollar header wrap and use ceramic spark plug boots to protect your plug wiring.
Just my $.02 worth.
Rusty
Customized by rust.
« Reply #13 on: May 12, 2016, 06:56:11 pm »
Just my $.02 worth.
Rusty
Thanks a bunch Rusty, I'm fine and dandy with the extra noise of the headers as the improved airflow will be well worth with a bit more growl, and as you said I could always just get some header wrap if it gets to toasty under there. Makes sense to wait till the 6.2 swap to get fancy with it, I was thinking o doing something like this here when I get the stacks done https://www.youtube.com/watch?v=r4MuRQzl2Zc&index=18&list=PLRZWh2Hd5ui02e0nE9Zle7MYWbI-ApfIP
Offline DustyRusty
« Reply #14 on: May 12, 2016, 09:33:47 pm »
I like the look of those stacks but for appearance I'd want the mufflers under the bed.
Customized by rust.
