Author Topic: Dome light not working.  (Read 10062 times)
Offline Barraphernalia
« on: December 05, 2005, 11:05:00 am »
85 Silverado SWB-2WD
In the 9 years I've had my truck, the dome light has only sparatically worked half a dozen times or so for a couple of days at a time. I'm about to completely redo my interior and would like to fix this while I have everything apart. Does anyone have any idea where I could start?
Thanks,
Barry
Offline roundedline
Re: Dome light not working.
« Reply #1 on: December 05, 2005, 10:09:00 am »
Is the light blowing out?  Is there a bad ground, or a crosswire somewhere?  What are the symptoms leading to it not working.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #2 on: December 05, 2005, 10:18:00 am »
I guess I don't really know. It didn't work at all when I got the truck, and then one day, a long time ago, I opened the door and it came on (it worked normally- when doors were open and with the hedlight knob.) It worked for a couple of days or so and then stopped working altogether again. This has happened a few times over the years. I've never messed with it.
Offline roundedline
« Reply #3 on: December 05, 2005, 02:40:00 pm »
« Reply #4 on: December 05, 2005, 03:36:00 pm »
No.
Offline roundedline
« Reply #5 on: December 06, 2005, 02:53:00 pm »
Is the dome light getting power to it?  There may be a short in the wiring going to the dome or the one in the door switch wiring.
Project Su
Jimmy 2WD Project
Offline 123 pugsy
« Reply #6 on: December 12, 2005, 08:00:00 pm »
I've had this problem before.I found door switches in pillar corroded allowing it to function intermittantly.Changed switches(they were both bad) and worked fine......until they rusted again....
Pugsy
76 C10 LWB
TPI 350
« Reply #7 on: January 08, 2006, 01:34:00 pm »
Thanks for your replies, sorry it's taken me so long to respond. I guess I'll work my way from the light back with a volt meter when I start taking everything apart. (and I'll check those door switches)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #8 on: January 19, 2006, 12:35:00 pm »
It wouldn't be the door switches if the light does not come on by turning the headlight switch all the way counterclockwise.  The headlight switch would override the door switches.  I agree w/ Chris....look at the wiring.
SgtDel
Offline 123 pugsy
« Reply #9 on: January 22, 2006, 07:52:00 am »
Whoops! Next time I should read the thread more carefully before I reply.I agree,it shouldn't be the door swithes if it doesn't work with the switch knob.
Pugsy
76 C10 LWB
TPI 350
