Author Topic: The Joy of water leaks....  (Read 5512 times)
Offline Tommyd11730
« on: May 08, 2016, 03:35:02 pm »
I went through this with my 91 K5.  When I asked the seller about his 84 K2500 the first question, "any water leaks".  None was his answer.
So here we are. Dash pad out, rug and seat out.  Cowl off.
Looks like the windshield is leaking (big surprise ) and both cowl vents. Non AC truck mind you.  Now apparently there was a TSB for the cowl leak.  You remove the vents and add water deflectors. The number is listed as unavailable so I may be up the creek on that one.
Feel free to chime in with your water leak storys.
1991 K5
1984 K2500
Offline Tommyd11730
Re: The Joy of water leaks....
« Reply #1 on: May 11, 2016, 09:46:15 pm »
https://vault.myvzw.com/webcs/app/share/invite/silH3y4T9x
Yeah..... about that windshield leak.  Spent the day repairing a couple of rust holes.  Used a rust converter first, and you know the drill.... marine text (on strike can't use the welder at work) AND a liberal amount of seam sealer.
Couldn't make it any worse that's for sure!
1991 K5
1984 K2500
Offline Tommyd11730
« Reply #2 on: May 14, 2016, 09:50:07 pm »
Replaced both kick pannel/fresh air vent gaskets.  Ones from   are THICK!!!  Not so sure that's a good thing.  So to recap I..
Replaced windshield and repaired rot holes in the frame
Cleaned and resealed cowl
Replaced kick pannel fresh air gaskets
Replaced body to door seal
Bring on the rain!
1991 K5
1984 K2500
Offline biker328
« Reply #3 on: June 08, 2016, 12:55:57 am »
I have a leak in my dime light. Driving or not. I have no idea.
« Reply #4 on: June 08, 2016, 10:28:37 pm »
dome light?
have you check your roof for holes?
Offline biker328
« Reply #5 on: June 09, 2016, 02:59:07 am »
yeah no holes, New paint even. The only thing I can think of is a small crack where the outer and inner sheet metal were molded together.
« Reply #6 on: June 09, 2016, 02:53:06 pm »
high mount brake light or cargo light?
