Author Topic: Cooling a 400  (Read 4363 times)
Offline gwcrim
  • Far from a Newbie
Cooling a 400
« on: May 14, 2016, 11:04:16 am »
Things are coming around quickly.  I need to sort out my engine and trans cooling.  The 400 is 9.5:1compression with aluminum heads, so it's not radical.  I have a brand new 3 core replacement radiator that would have come in a 400 C10, shroud and a 7 blade clutch fan.  I believe that would work, no?
The trans is a built 200-4R.  To cool it, I have a 15"x8" 16 pass cooler.  That's more than enough so I plan to use it and bypass the one in the radiator.  Here's my big question.  Because the trans cooler is about 25% of the size of the radiator, will it block too much air and cause the engine to overheat?
Offline Engineer
Re: Cooling a 400
« Reply #1 on: May 14, 2016, 03:24:40 pm »
My 400sb came with a 4-core radiator the same model used in the 454 trucks. My truck had an auto trans and A/C.
The transmission cooler shouldn't be a problem. The A/C condenser, if you have one, covers the entire front of the radiator opening.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline gwcrim
  • Far from a Newbie
Re: Cooling a 400
« Reply #2 on: May 14, 2016, 05:03:51 pm »
I think I've devised a way to mount it to the middle support.  That would keep it 4-6" in front of the radiator.
Offline gwcrim
  • Far from a Newbie
Re: Cooling a 400
« Reply #3 on: May 15, 2016, 02:36:05 pm »
It's been a year since I ordered the radiator.  Opened it today for the first time.  This is what I have:
http://www.summitracing.com/parts/pli-433161
It's a BIG single core.  Adequate?
Offline Captain Swampy
  • Wisconsin
Re: Cooling a 400
« Reply #4 on: May 21, 2016, 02:41:29 pm »
Keep the coolers close together. If you leave a big gap, the air will flow around the tranny cooler, not through it.
