Author Topic: 1987 Chevy Suburban Headlight Wiring Harness  (Read 4498 times)
Offline rcollamore
« on: May 26, 2016, 12:14:19 am »
I am looking for the name of the piece that is at the end of the headlight wiring harness that connects to the fuse box on the firewall.
I just that part to get my headlight working because I am missing mine and I am unable to connect the headlight wiring up. And I don't want to buy the whole head light wiring harness seems like a waste if I am able to find that part.
Sent from my VK810 4G using Tapatalk
Offline LTZ C20
Re: 1987 Chevy Suburban Headlight Wiring Harness
« Reply #1 on: May 26, 2016, 01:56:20 am »
It's called the bulkhead connector.
LTZ Cheyenne C20
Offline hatzie
« Reply #2 on: May 27, 2016, 04:46:38 am »
The bulkhead plug,  on the engine compartment side, is actually several plugs that fit together.  Most of the bulkhead connector pieces are discontinued.  The discontinued 1987 forward lamp harness connector is Delphi Part # 8917233.  It takes Packard 56 female terminals.  You can buy the terminals but the connector is only available if you want to buy an entire production run of several thousand or find one used.
You can find a PDF of the 1987 GM Light Truck full line Wiring Manual in one of the folders linked in my signature.  The 1987 squarebody is an RV series.  The RV series forward lamp harness is on page 167 & 168.
« Last Edit: May 29, 2016, 06:52:09 pm by hatzie »
Offline rcollamore
« Reply #3 on: May 27, 2016, 09:16:54 pm »
Thank you for help with that lol ya I tried looking for one after I saw your answer lol I think I am going to see if I have any luck at junk yard.
