Author Topic: bedsides mostly bolt on?  (Read 6726 times)
Offline slimsi99
« on: February 18, 2006, 04:26:00 pm »
Change of plans from buying a complete bed. The righthand side is the only thing messed up so I am looking a doing just a bed side.
I have been told by a few people that the bedside on my '86 longbed C10 is mostly bolt on with exception of a few small welds. Is this something that is true? If so it would make alot more sense to just fix the one side rather than swap the whole bed.
Also are the   bedsides about the closest that I will get to having the same gauge steel as a factory GM bedside?
Offline bigblock73
  • Yeller
Re: bedsides mostly bolt on?
« Reply #1 on: February 18, 2006, 07:35:00 pm »
The beds are 99.9% bolt on, with only a couple small spot welds below the tailgate area.
This will help answer any other questions you might have.
www.73-87.com/7387garage/...ebuild.htm
...Jeff
'73 swb 2wd
73-87.com
Jeff
'73 swb 2wd
73-87.com
Offline 123 pugsy
« Reply #2 on: February 20, 2006, 04:41:00 am »
Make sure you weld it at same places when you install it to keep it from working loose and shaking around later.
Pugsy
76 C10 LWB
TPI 350
Offline slimsi99
« Reply #3 on: February 28, 2006, 06:57:00 pm »
Thanks guys, that definetly tells me that I am going to buy a new bedside.
